Old 05-10-2017, 03:20 AM   #1
upgasgas1224   upgasgas1224 is offline
upgasgas1224's Avatar
2005 flywing 150 info and help needed!
Hello first off let me say im rather impressed with the bike so far but i have a few questions.
1. What plastics will work on this bike. I need tank plastics and a rear fender. Already got a universal front fender on the way just cant source a suitable set of tank plastics.
2. the bike seams to back fire and bog if held wide open. ive cleaned the carb and adjusted the valves and it idles much, much better but in high rpms its almost like it either has no back pressure with the stock exhaust or the cdi is cutting out....? anyone else have this issue and/or could give me advice to fix it?
3. the rear rim and sprocket is rather trashed any suggestions on a replacement?
Thanks all!
04 flywing 150
05 flywing 150
07 gasgas ec200
18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come
Old 05-10-2017, 03:26 AM   #2
general idea of model
Not my bike but mine is nearly in the same condition as this one so everyone has an idea of which model I own. https://www.google.com/search?q=spro...CgtgV7OHyX5QM:
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-10-2017, 07:06 AM   #3
humanbeing's Avatar
Infamous carb syndrome http://www.chinariders.net/showthread.php?t=16541
Most old chonda are based from 80s XL125S. http://www.jtsprockets.com/catalogue/sprocket/JTR269 is the De facto choice. REAR Hub had 2 common size https://item.taobao.com/item.htm?id=13627356748
Old 05-10-2017, 08:03 AM   #4
awsome!
Ill have to try changing that main jet like suggested. I changed the spark plug once but it may be fouled out again. I never would have thought about the gas boiling, i'll have to check to see if that's going on aswell because once its been running for a while it definitely seams to get worse as it gets hotter. Thanks ill update on thursday once i mess with it.
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-10-2017, 12:38 PM   #5
I have a Lifan with a similar plastic tank and I deleted the tank covers. I like it much better that way.
Old 05-10-2017, 01:22 PM   #6
do you know what plastics fit your tank it does look very similar and prolly wouldn't be to hard to modify shrouds to fit.
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-11-2017, 12:31 AM   #7
No idea. Mine were broken so I was happy to toss them out.
Old 05-18-2017, 10:07 PM   #8
carb specs
anyone know what carbs are compatible replacement wise this stock one is just trash in my opinion
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-19-2017, 02:07 AM   #9
According to HB, this is it: http://www.ebay.com/itm/VM22-Mikuni-...pXy~AZ&vxp=mtr
You can save a few $ if you order from China.
Old 05-19-2017, 02:50 AM   #10
humanbeing's Avatar
Pz27 definitely the No-brainier 1. Direct fits 2. Jetted for 150 3.CHEAP -fleabay: ~$14
Old 05-19-2017, 07:55 AM   #11
somthing a bit up from a pz27 even. i hear these nibbi carbs are awesome im just not sure about how to fit it. https://www.amazon.com/NIBBI-Replace...bbi+carburetor
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-19-2017, 08:32 AM   #12
Bruce's   Bruce's is offline
What jets does that carb use and where are you going to get them ?read the questions about the carb ,the seller doesn't seem to helpful from the several I looked at ,if you run in to trouble with the carb thanking you and hoping you do business isn't going to help you at all to get your bike running again .If the jets are mikuni ,they are easy to find at most bike shops ,anything else is harder
Old 05-19-2017, 02:33 PM   #13
not sure kinda why im asking you guy's. the carb thats on this thing is a pz27 clone but it leaks gas out of every spot possible and the main jet is pitted and corroded so bad i cant get it out without stripping threads.
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-19-2017, 02:35 PM   #14
they use keihin jets so any honda dealer should have them.
04 flywing 150
05 flywing 150
07 gasgas ec200
Old 05-19-2017, 05:01 PM   #15
humanbeing's Avatar
I bet the stock is a Walbro PZ26 cuz that youtube dude said "90" in http://www.chinariders.net/showpost....88&postcount=4 & https://en.wikipedia.org/wiki/Common...es#E10_or_less unfriendly
