Old 11-06-2023, 07:25 PM   #1
Originally Posted by Zapkin View Post
I walked out today, and it fired right up and idled without any choke or anything. It was about 58 degrees. I hadn't even run it the day before. Man, it is running so good; I hate messing with it. There is no throttle bog, it's not cutting out. Hell, now with valves done, it runs even better. The only reason I want to deal with the carb at all is that I was told my plug is showing it's too lean, and I invested in that Nibbi filter (hehe, yes, I am that cheap). Other than that, I have absolutely no reason to touch the carb. FWIW, running at half choke works, but the bike loses power.
GREAT to hear it's running right. Nice going! Now you have a base set of settings (airscrew turns, pilot and main jet size, needle shim...). What are they? You can now exploit what you've learned to improve performance!
