06-16-2016, 11:13 PM | #1 |
Broken Skid plate welds......
I've just hit 2600 miles on my bike so I thought it do an oil change and switch to the 20w50 that was rumored to be the bees knees. Long story short.. I discovered my skid plate mounting bracket welds have rusted completely through and have broken off. The welds had pretty much corroded into red dust inside the paint. It looks as if the paint was the only thing holding it together until that finally gave up. It's starting to make me worry about the welds on the rest of the frame and what other severe corrosion is developing in other areas that I can't see. I've taken the skid plate off for now until I figure out if I'm going to spend the money for the upgraded skid plate or if I'm going to try and re attach the mounting bracket some how. The 20w50 is pretty smooth in the engine and has made neutral much easier to find. I'm in Southern California so the weather is typically warm so I dont know how it would perform in colder areas. I've been trying really hard to love this bike like I used to but the skid plate thing (among many other things) is making me lose confidence in the quality of manufacturing. I've had a fair amount of problems with my bike but I've over looked them all because CSC has always had such amazing customer service and has always been willing to help me out which I believe is awesome. Im still flip flopping over just cutting my losses and selling the bike.. I think I'd happily take $3500 for the bike and I just may throw it up on Craigslist tonight and see if there's any interest here locally.
06-16-2016, 11:34 PM | #2 |
I was looking at the welds too and, I agree, they are so-so. I would thing some frame prep spray would be useful.
https://www.amazon.com/Weigles-Bicyc.../dp/B0012GO58Y I use to use this stuff on all my bike frames, steel is real.
2016 CSC RX3 Silver Last edited by Rodtheviking; 06-29-2016 at 09:18 PM. |
06-16-2016, 11:47 PM | #3 |
It's probably wise to keep an eye on all the welds for now. This skid plates broken on a few other bikes at that mounting point as well. It's probably not a bad idea to reinforce it with some radiator hose clamps or carry large zip ties for when it breaks.
06-17-2016, 12:29 AM | #4 | |
06-17-2016, 09:55 AM | #5 |
I do not think the welds are a problem, they are still intact. The problem is most likely due to impact causing a crack, which becomes rust and finally failure. The aluminum skid plate is much more secure. Most OEM skid plates are just barely adequate for real off road use so this is not unique to Zong. I'm very happy with the optional aluminum plate offered by CSC.
06-17-2016, 03:15 PM | #6 | |
06-17-2016, 11:43 AM | #7 | |
I almost NEVER sell a bike I've bought unless it turns out to be NOTHING like what i was expecting after a very in depth research, examination, test ride etc. -which i do before a purchase. consequently I have several garages of bikes,including several bikes purchased over 30 years ago, from a number of different manufacturers. I have NEVER had a welded piece rust off, that's NEVER! I've had some cheap ass oem screws and bolts go bad, but stainless replacements were easy to come by. On this board, almost ten years ago, is the long THREAD of my first china bike, "WALDO" along with a bunch of high def photos of running him thru rivers, mountain mudholes etc.He's the cheapest "pos" bike I ever bought. Waldo is still alive, runs great, NO rusted frame parts. I think i paid something around 7 or 800$ for him, and abit more for shipping. He is NOT a Zong....and the welds look like something a five year old did, but they haven't rusted.....and he's spent his life in the dirt, the mud, and crossing water.. In short, rust on "ALL BIKES" my azz.....
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
06-17-2016, 01:21 PM | #8 |
OK, your azz. I do welding. From the photos the weld is still 100% intact. There was decent penetration. The part did not "rust off". Just look at the edges of the weld where the metal is broken off. That's a sharp edge. The sharp edge is due to a crack and the rust you see is just normal surface rust that you get from bare metal exposed to the atmosphere. The rust is also fairly recent, otherwise it would be crusted over and expanded. No, this is a crack that was either caused by impact or vibration. I'm now of the opinion that vibration is the culprit since others have had exactly the same problem.
06-17-2016, 02:27 PM | #9 | |
Do you think this problem could be fixed if they would have welded all the edges of the "feet" that attach it to the frame or would that just move the vulnerable "possible crack area" further up the chain?
06-17-2016, 03:30 PM | #10 | |
06-17-2016, 10:24 AM | #11 |
RX3 James, what other issues have you had with the bike?
Also, the quick fix for that is a couple of hose clamps and you're back on the road. These are the only welds I've heard that have ever given a problem. It is strange that you are in So Cal and these rusted. Are you close to the ocean? Rust usually isn't an issue out west.
06-17-2016, 03:05 PM | #12 |
Battery died at around 200 miles( I bought a new one with a two year warranty ), front rotor was warped causing pulsating front brakes (replaced under warranty ), had a chain issue causing it to scream really loud even with proper tension and lube (bought upgraded chain ), right side mirror broke off (replaced under warranty ), The engine likes to die at random times, like it just completely shuts off and wont restart until I come to a full stop and shift into neutral and restart (has happened in heavy San Diego traffic twice now which was pretty nerve racking ) the engine temp runs between 4 and 5 bars constantly (but the fans do come on and I haven't over heated so I'm not too worried about that... but it does add a lot of heat in my ATGATT in Southern CA stop and go city driving)
06-17-2016, 03:34 PM | #13 | |
06-17-2016, 03:46 PM | #14 | |
Come to think of it I never had this issue until after I replaced the OEM battery so maybe I should take a better look.... my 2nd thought was something that Spud had mentioned to me a few months ago. He said my valves might be too tight which could be causing the dying issue. I think I'm gonna check them on sunday and take them all the way out to 0.8mm and see if that makes any difference. |
06-17-2016, 04:58 PM | #15 | |
My bike had about 80 miles on it (my brothers had 17) and after I put 100 miles on it, I wanted to check the valves, just in case, since they hadn't been set by CSC. All but one were at .08MM. Just one was a little tight. I'll be setting mine at .08MM from here on out. It really does sound like you have all the normal bugs worked out. I hope you decide to keep it. I really enjoy mine. It's a fun bike to ride..and when the rotor warps, I'll replace it, etc...etc... At least I won't be surprised! ;-)
