02-07-2016, 03:41 PM | #1 |
Fuel Trouble
Hello I have a 2006 Kesea Skyhawk 250 t has a twin carb and cyl. I have new carbs wires coils spark plugs and cdi . Still would not start so I got a cross over pipe to make it a single carb. It will start but only with starting fluid. Just don't know with new carbs. Anyone know what could be wrong?
Thanks Scott |
02-07-2016, 10:27 PM | #2 |
Please show us the carb.
02-07-2016, 11:33 PM | #3 |
Here are two.
02-13-2016, 08:08 PM | #4 |
Ok I did adjust the valves today and got it going but it will only run with the choke full on now . So I tried to adjust the carb but just with the choke on it runs great lol . any help?
Thanks |
02-13-2016, 08:13 PM | #5 |
jets to small? or cam timing off, causing low vacuum? bad rings? stuck valve? ... could be a number of things really
02-13-2016, 08:24 PM | #6 |
I don't no if they are or not but there brand new carbs .
02-13-2016, 08:34 PM | #7 |
could be something as simple as not remembering to tighten your spark plugs ... guess how i know that ... lol
02-13-2016, 08:37 PM | #8 |
did you check float levels?
02-14-2016, 12:36 AM | #9 |
No I did not does anyone know what they should be?
02-14-2016, 01:35 AM | #10 |
After I did a valves adjustment there is a ticking now when running with the chock full this is a Kasea Skyhawk 250 with twin cyl would anyone know what side is number 1 left or right?
02-14-2016, 10:34 AM | #11 |
sounds like if it it ticking now after adjusting the valves, they are not right still
02-14-2016, 12:29 PM | #12 |
All else aside, the slow jets sound like they are too small for the application.
02-14-2016, 02:19 PM | #13 |
So how far up should I go up with the Jets and where do you think I can find them st for a Keihin PTG carb ?
02-14-2016, 05:58 PM | #14 | |
--- https://translate.google.com/transla...8611&sandbox=1
02-14-2016, 06:43 PM | #15 |
hank you humanbeing I will take mine apart and see.
