08-24-2015, 10:57 AM | #16 |
Was there any difference after you turned the pilot mixture screw out 2.25 turns, per HB's advice?
08-24-2015, 03:06 PM | #17 |
Not really still doing the same thing will not run unless choke is closed and I'm using the throttle it will not idle by its self.l did talk to the someone where I bought the parts at he thinks it's a not getting enough fuel or a valve is stuck open or rings are not setting. Tonight I'm going to do a compression test then do one after that with some oil in the cylinders see what happens.
08-24-2015, 11:46 PM | #18 |
It never hurts to set the valves, for sure.
What size is the slow jet?
08-25-2015, 12:54 AM | #19 | |
=== No brainier package http://item.taobao.com/item.htm?id=14549102724 2 to 1 thingy | Genuine Keihin carb (Made in China) | FREE throttle cable | Re-jet maybe needed because that's stock CM125 carb…
08-25-2015, 08:11 AM | #20 |
Humanbeing that looks just like the carb on this one but two of their would that manifold work with mine ? And how much is it?
I did a compression test as per the the manual both plugs out throttle wide open one had 140 the other 130 + or - few pounds . So I thinks it's not the valves or rings. I would like to get this thing running because I feel it would be fun to ride plus I have all new body parts for it. Thanks |
09-17-2015, 12:01 AM | #21 |
humanbeing AJ parts sent me that manifold for free with the carb because I have 2 new ones but that manifold will not bolt up to my motor my bolt go across not some what up and down.So that will not work if someone know how to let me know. What would that motor be clone to?
