04-29-2015, 02:41 PM | #526 |
At the very least, the bike is running well, and you have more spare parts. Call it a win.
04-30-2015, 12:28 AM | #527 |
x2.
04-30-2015, 08:23 AM | #528 |
Delved into the issue with the spare set and found a bum emulsion tube for the slider. It was obvious that someone had been in them once before(permatex #2 on the bowl gaskets)and got a bit overzealous cleaning the tube. There is no seat left in it for the needle to sit on.
Like you guys said, I have bunch of spare parts now and they are really clean.
05-24-2015, 08:28 PM | #529 |
My wife finally finished her Snapple.
I have a total of two bucks into it and that was for the two rubber stoppers. Everything else was hiding in the garage. I haven't hooked it up to the bike yet but I did connect it to my Mity-Vac and it does work like it should. I'm too pooped after playing with the grandson all morning. Also getting over the nasty cold he shared with Mrs. C and I.
05-24-2015, 09:20 PM | #530 |
I have a pair of 1/4 20 concrete ancores in the floor of my garage about 16" apart. To lift a front end, screw in eye hooks and put bike on center stand and use a pair of straps to pull the rear end down. This works with and bike or scooter with a center stand. Keep a couple short 1/4 20 screws in the floor when not using the "lift" john
05-25-2015, 11:41 AM | #531 | |
05-25-2015, 11:41 AM | #532 |
Cheesy, what are you using for liquid?
05-25-2015, 03:24 PM | #533 |
ATF.
Not gonna try it out today as I hoped. The 'Gift' cold has had me whorfing up lung butter since last night. Saying I felt like crap would be better than I feel right now.
05-26-2015, 12:53 AM | #534 |
I hope you feel better soon.
Kids share colds well, don't they?
05-26-2015, 08:33 AM | #535 |
Grandkids seem to instinctively know who to aim for.
05-30-2015, 09:54 PM | #536 |
Well, that was fun.
Jumped on the CX yesterday morning to go to work. Pull the choke, turn the key, punch the starter button, aannnnndddd nothing. Punched it a second and a third time, still nothing. Fourth time was a charm. Get to work with no issues. Park the bike and try to restart. Nothing. I decide to wait until lunch time to look at it. Lunch rolls around and I try to start it. Nothing. Not even a click. I push the beast into the shop and break out the DVOM. Getting nothing at the solenoid. Take the right control apart to access the starter button and open that up. To say the guts of the switch were disgusting would be an understatement. Clean that up and polish the contacts. Reinstall and test. Woohoo, it works. Roll the bike back outside. Quitting time. Suit up, hop on the bike, turn the switch and punch the starter button. NOTHING. Fiddle around for a few minutes and it starts. Get home and pull it into the garage. After dinner, I start trouble shooting. Again, I break out a DVOM and again I have no juice at the solenoid. For grins, I took the starter button out again to double check that I didn't screw something up. Nope. Put the switch back in and check for voltage at the switch. 12.75V at the starter wire, nothing at the solenoid. Ahh, so I either have a crudded up connection or a wire break. I call it a day because further digging will require removing the fuel tank (full) and dismantling the headlight. At 5:30 this morning, I remove the tank and open up the headlight. I find the starter wire in an 8 pin plug. Pull that apart and take a looksee at the contacts. Ummm, a little corrosion but not enough to cause the problem. I check continuity from the starter button to one end of the plug. BEEEEEEP. I check from the other end of the plug to the solenoid and nothing, so it's a wire break. I decide to clean all the plugs while I'm in there. Get that done and start chasing the wire break. At the first touch of the main harness I get BEEEEEP. I undo the electrical tape and the break was staring back at me. This was in the section of the harness that was damaged when I got the bike and I repaired. I hadn't repaired that wire at the time but it had been worked on in the past. Besides, I use heatshrink on splices, not tape. By the time I cut out the corroded wire, I needed to add a three inch splice. All soldered and sealed as neat as can be. Put everything back together and I'm golden. Starter sounds happier, too. BTW, I sprung for a new solenoid. Just in case.
05-30-2015, 10:03 PM | #537 |
Nice work. Dang mysterious broken wires.
05-31-2015, 12:18 PM | #538 |
That's not standard procedure.
Good call on buying a new solenoid; might as well know that it's handled as well.
05-31-2015, 03:44 PM | #539 |
My GL occasionally had a similar problem on my Alaska trip. Tapping on the solenoid would make it start. Turns out the tiny electromagnet coil wire broke where it exited the coil to go through the plastic cap. Unfortunately there wasn't enough sticking out to solder it so I unwound the the spool, pulled the wire through a bit more, then rewound the spool using an electric drill. It's worked fine since. Am I cheap or what
05-31-2015, 07:03 PM | #540 | |
