Old 10-29-2021, 10:41 PM   #1
goJimH   goJimH is offline
Doh! New Tao MC-T07 150cc Scooter Engine dies after 4 or 5 minutes
Received a new Tao Tao MC-T07 150cc scooter for wife. It runs fine for a file then engine goes dead. Attempts to start - zero ignition action. Let it sit for 10 or so minutes and it will start and run fine again.
Suspect an ignition problem but not sure where to start looking.
All suggestion / insight would be appreciated.
Jim H
2020 Lifan X-Pect - VIN # 157
JTF1264.17 Front Sprocket
Learning as I go - Trying to get cost of my education down!
Old 10-29-2021, 10:44 PM   #2
Merlin   Merlin is offline
Could your valves be too tight?
Bashan Blaze
Old 10-31-2021, 09:17 AM   #3
Merlin,
Thank you. I have not checked the valves so will try that.
I was thinking electrical (CDI, Coil) - as when it dies - it dies suddenly - like a light bulb going out.
Old 11-01-2021, 08:11 PM   #4
krat   krat is offline
Classic stuck float bowl situation. The float valve is not moving to allow fuel into the carb at a normal rate.
When you run the fuel out of the bowl it stops. When you let it sit 10 minutes the bowl refills.
It might just be trash blocking the float needle.
Now it's time to learn about taking apart Chinese carbs!
I recommend Brent over on You-tube at 49ccscoot. He gives very detailed instructions on all matters GY6.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
Old 11-08-2021, 08:30 AM   #5
Badluck   Badluck is offline
I'll add to the list of possible issues, a clogged fuel tank vent.
