Old 06-01-2015, 07:30 PM   #31
weiser23   weiser23 is offline
it seems that i lost second gear. it grinds like hell if i give it gas or down shift. even pushing back and forth with engine off . i guess i will have to skip 2nd
Old 09-22-2015, 09:35 AM   #32
have been riding without 2nd and 5rd gear for awhile,i tightened my chain cause it was really loose and i started getting really bad grinding , after checking i found the chain was hitting engine guard. so i know the chain is bad.but i started the engine and still have grinding. after take side cover off i found the whole clutch basket had a 1/2 inch movement in all directions, the washer still bent over to keep nut from loosening. what is the next thing to do without opening the cases or trashing the bike.
Old 09-22-2015, 09:47 AM   #33
Mudflap   Mudflap is offline
I would remove the clutch assembly to have a look at the splines on the clutch basket. They are usually aluminum and ride on the hardened steel input shaft. They eventually wear out and the clutch becomes loose. A complete clutch assembly runs about $40 on Ebay.
BTW, the clutch basket splines were starting to wear on my Lifan 200 engine so I replaced the clutch. Easy job.
Old 09-22-2015, 12:08 PM   #34
I took the clutch basket off and it looks like the shaft it self has a lot of play in it ...it should not have a lot of play in it right ??????
Old 09-22-2015, 02:51 PM   #35
Correct. The transmission input shaft should not have a lot of play. The shaft is supported by ball bearings on both ends and the only way to change them out is to split the crankcase.
Old 09-22-2015, 04:03 PM   #36
what would cause the clutch and transmission to act up by just tightening the chain
Old 09-22-2015, 04:58 PM   #37
May have nothing to do with tightening the chain but there is a chance it's related. If the chain is overly tight it puts a lot of stress on the countershaft and bearings which could cause problems with other transmission parts.
Old 09-02-2016, 12:01 AM   #38
Rv   Rv is offline
Originally Posted by weiser23 View Post
bought a clutch from ebay every thing seem to match but they had 5 steel plates instead of 6 so i used 1 old one and now the clutch wont work at all , it still goes through the gears with engine off, and starts and sounds ok but if you try to start the engine in gear with clutch on it did not work and clutch is real tight. this sucks its the best time to ride and im stuck driving my car
So the dr200 clutch works in the xf200?? I've been searching for this answer for weeks haha
Old 09-03-2016, 12:42 PM   #39
Hey there. Apologies for the delay. I've heard the 125 clutch will do the trick but my Q Link clutch has yet to need replacing so it's a guess. Wish I could be of more assistance.
I'll do some searching and see what I can come up with.
Old 09-12-2016, 08:06 PM   #40
Rv   Rv is offline
I got it, the dr200 clutch is a perfect fit!
