Old 06-18-2016, 09:56 PM   #121
RuthlessRyder   RuthlessRyder is offline
Oh my. Did a weld break?
and then some it was sepatated at both ends and broke in the middle - very thin steel 1/16 thick.. I replaced it with 5/16 thick stock the same size and just got it back together
Old 06-18-2016, 09:58 PM   #122
Just what size a dog are we talking about?
a 60 lb pony riding dog (grins)
Old 04-29-2017, 12:35 AM   #123
roy12986   roy12986 is offline
Bed liner
What are the cooler lines for? It looks like they connect to the engine, but I can't be sure. The cooler that is in front of the rad looks to be very well thought out.
Any idea what the engine is patterned after? I wonder if it's like a Kawasaki Mule.
Have you considered spraying bedliner in the box? I spotted the box mat, but it's the sides I'm thinking about.
I have the Ranch Pony 2013. The first thing I did after putting it together was spray that box with Rust-Oleum Truck Bed spray it worked great.
Old 04-29-2017, 12:57 AM   #124
OK I need help everyone. I'm disabled I bought this ranch pony 500 because I have trouble even walking. I wanted it not only to get around my property but to be able to hunt. NOW it's stuck in 4X4 and won't shift back to 2wd? I did everything like before but no luck still says diff lock? And as for the damn carb I had the same problem a previous guy had here with fouling plugs. I can only get two of the 3 screws out of the carb bowl and like also said the fourth is a rivet. BUT I FOUND THE AIR FLOW RUBBER PLUG ON THE BOTTOM IN THE BACK OF THE CARB. I'm hoping if I adjust this I can solve this issue. IF ANYONE KNOWS WHAT TO DO ABOUTTHE 4X4 PLEASE HELP ME. This is a bitch to turn when not in 2wd. Thanks
Old 05-01-2017, 12:22 AM   #125
http://www.ebay.com/itm/Oil-Filter-R...item2a3a7da400
I order 6 so I have extras they fit perfect. EBay once again LOL.
Old 05-01-2017, 12:27 AM   #126
order 6 from ebay they fit perfect 9.50 bucks each
Old 05-01-2017, 05:50 AM   #127
humanbeing's Avatar
https://translate.google.com/transla...1%26start%3D15
Originally Posted by roy12986 View Post
JX0604 = For those ugly vehicle (Workable 1 just ~$300 in rural PRC ) -Daihatsu Charade | Suzuki Alto/ Carry... & knockoff
https://catalog.mann-filter.com/EU/e...ilter/W%2067~2| http://www.hiflofiltro.com/catalogue/filter/HF682
bms ranch pony 500, utv
