05-07-2020, 06:11 PM | #1 |
Battery Isolator
Im going to connect both my batteries by using a battery isolator and what i wanna know is will a inline fuse of 25amp be enough to put between the second battery and isolator?
also what gauge wire should i use for this. also can i connect the ground to neg terminal on battery 2 |
05-08-2020, 08:39 PM | #2 |
I don't trust isolators. I'd rather use a constant-duty solenoid, like what GM uses when you order a second battery in a Silverado.
