Anybody with technical specs??
Can anybody tell me the primary drive ratio on a 200cc bike (OHC or OHV)?
Jonathan. |
My standard ratio is as follows:
Primary Drive Ratio 3.333 1st Gear Ratio 2.909 2nd Gear Ratio 1.867 3rd Gear Ratio 1.389 4th Gear Ratio 1.150 5th Gear Ratio 0.955 Front Sprocket (Teeth) 17 Rear Sprocket (Teeth) 46 Rear Wheel Rim Size (Inches) 18 Total Ratio 2.71 |
Spot on just what I needed, apart from 1st gear (which on th 125cc is a little taller, the internal ratios are the same.
Thanks, Jonathan. |
