10-23-2017, 09:08 AM | #1 |
Hawk 250 - Is It Ok To Just Change Rear Sprocket?
So I would like to do the 17/45 sprocket changes that everyone recommends to gain some top-end speed on the highway on my Hawk 250. But I am nervous about going bigger on the front sprocket in the event of a chain failure resulting in a damaged case. Probably a one-in-a-million-rare chance but I dont want to chance it.
So I was informed that I can go with a 40-tooth rear sprocket and leave the stock front sprocket in place for the same gearing result as 17/45. Does this sound accurate? And will there be any disadvantage to changing just the rear sprocket to a 40-tooth? Just wondering if there are any disadvantages since people usually change both sprockets for this change, thanks. |
10-23-2017, 09:25 AM | #2 |
40 tooth rear will be very close to the 17/45 combo with 15/40 being slightly lower. That's what I run when I go strictly off road. You can always change the front to a 16 or 17 later on if you plan on just street riding. Here is a link to a sprocket calculator. just type in Hawk in the filter and then select Hawk 250. http://woodsware.aciwebs.com/gears/ You can play around with that to figure out what you want to do. I'm currently running 16/40 because I have been doing about 50/50 on and off road cruising 55-60 mph on the highway.
10-23-2017, 11:47 AM | #3 | |
10-23-2017, 11:53 AM | #4 | |
10-23-2017, 12:18 PM | #5 |
Great! Thanks so much for your help!!
10-23-2017, 12:20 PM | #6 |
Only reason you would need to change both sprockets and chain is if your current sprockets are showing some wear.
10-23-2017, 05:32 PM | #7 |
I find this website to be handy: http://www.sprocketcalculator.com/
