03-01-2017, 04:20 PM | #8 |
transmission
Hello....your gearbox shifter is not adjusted right... you can take off the link to he box from your gear shifter and you will see it can go more.. so it is in gear completey.. simple adjustment.. some one else had this problem acouple of post ago... but remove the link and see the main link will go into gear FULLY then... reinstall link when fully in gear... and then check reverse gear... DO NOT GEAR AND REV LIKE THIS.... HARD ON THE GEARBOX.... this is how people give the Chinese brand a bad name... since the buyer assembles it you are responsible to adjust stuff... the dealer if sold assembled is respossible.. thanks
