04-06-2021, 12:16 PM | #1 |
Wildfire WFG-200LDB help
Hi just got the wildfire wfg-200ldb, and am trying to get it started again. Guy i bought it from says that the rubber intake boot needs replaced and he showed me the crack in it. Its been sitting for the winter needs some tlc and rust removal but engine turns over. Looking for help on where to get parts i need that intake boot and dont know where to find it and cant find anything to explain how to fix also. Just looking for some advice couldnt find anything until i got here. Thanks for any help
04-06-2021, 01:18 PM | #2 |
Welcome aboard! There are several styles of intakes available. Take a picture of the existing boot so we can help you find the right one.
04-06-2021, 02:08 PM | #3 |
Awesome thank you i really appreciate the help im gonna send a picture along with this reply.
04-06-2021, 02:24 PM | #4 |
Okay, thats the same as Hawk and few of the other CG250 engines. https://www.amazon.com/dp/B08HQKHWGS...ding=UTF8&th=1
04-06-2021, 02:48 PM | #5 |
That looks a lot like the same style used on the Magician and a couple other bikes where it cants to the left side of the bike a bit in order to keep the carb straight. Style A from that link Jerry provided might be the one you need, but it's so hard to tell from the pictures that the sellers provide.
04-06-2021, 03:30 PM | #6 |
Okay i am going to try that one from the link thanks. Im gonna take off the cracked one and compare the measurements to make sure. Is it easy to take it off and put the new one on?? I dont know much about the bike. Anything helps
04-06-2021, 03:34 PM | #7 |
Very easy to remove and replace.
04-06-2021, 04:12 PM | #8 |
Also looking for the plastic that covers the battery on left side and cant find any bikes that r the exact same
04-06-2021, 04:18 PM | #9 |
You might be able to find body parts that match from Roketa.
https://www.roketapartsdept.com/roketa_dirt-bike_parts/
04-07-2021, 12:00 AM | #10 | |
04-10-2021, 03:48 PM | #11 |
Wildfire 200cc battery help
I got the rubber boot coming in a few hours. The batterys on the charger and once i cleaned it it didnt look like its in bad shape but it no lights come on unless its charging and as soon as u take the clips off it dies. Absolutely no reaction from the electric start on right handle( no matter how much i charge) and only the brake light and turn signals come on when its charging, the head light and tail light dont come on at all. Im wondering if anyone knows if i need a new battery or if its the cables or the lights??
