06-10-2012, 12:42 PM | #1 | |
06-10-2012, 08:24 PM | #2 |
Well didn't hv to split the case... found out its the gears on the rear wheel axel that are stripped out.. any idea where I can locate one? I live in new york
06-10-2012, 10:10 PM | #3 |
Ok so what it turned out being is the section of axel that goes through the differential, the small teeth on it are wore off enough for it to just spin. In need of a new rear axel.... any idea where to locate one?
06-10-2012, 10:41 PM | #4 |
dose the rear end have full diffarental mode or dose it just
change the drive direction ?.. I it's a full diff it has a a set of spider gears aswell as the crown wheel & pinnion... Spider gears are basicly a planetrey gear set...
06-15-2012, 08:24 PM | #5 |
Ok so I got the new rear wheel axle in mail today. I threw it into the rear end and that's all good but now I'm back to the drawing board..... put it in gear and it spins but then if I rev it up the axle stops spinning again. I am at a total lose now... please give me some ideas of where to go from here
06-15-2012, 08:56 PM | #6 |
I downloaded a repair manual for it and in there it says to back the adjustment screw for clutch out and turn in 1/8 turn... I did this and get same out come. Can I keep turning the screw in or shld it only go so far?
06-15-2012, 10:46 PM | #7 | |
If you get a chance please post a few pictures, it might help us diagnose your problems a bit better. Lot's of knowledge on this site (not me!) and I'm sure someone can help you out |
06-16-2012, 01:21 AM | #8 |
Thank u! The manual says to turn the screw opposite direction. I ran out to garage n did exactly what the guy did in video and the shaft was spinning like it should. Tomorrow I will put axle in and see what happens. I'll also mess around n try to post some pics. I really appreciate all the help so far.
06-17-2012, 09:09 AM | #9 |
No word for a couple of days, I'm hoping that means your ATV is fixed and your out bombing around on it :wink:
06-21-2012, 07:58 PM | #10 |
Either that or it didn't work and he gave up on it? Guess we'll never know! :wink:
06-27-2012, 05:55 PM | #11 |
Hey guys, sorry been couple days but to fill u guys in on were I'm at.... the you tube video worked great. Got the clutch adjusted and was able to wip around the yard on it a bit. Now need to locate some tie rod ends because the ones on it have some slop in them. I was told that these machines are very similar to the older honda's. Is this true? I also need to put brake pads on the front and some other minor tweaking/adjustments. But for the most part it is up and running!
06-27-2012, 06:05 PM | #12 |
....... and i am NOT giving up on this machine :P i got it for dirt cheap and have literally only put a rear axel ($79) and bought all new brake pads ($35) this machine seriously looks brand new. i cannot wait to see how it handles once i get it out of the grass and into the dirt
06-28-2012, 12:36 PM | #13 |
Good news! Thanks for the update.
06-28-2012, 06:04 PM | #14 |
i am not sure if this will work but here is a link from the ad i bought my atv from. btw it looks alot better now that it is sitting in my garage
http://www.google.com/imgres?q=diamo...s99j7BQ&zoom=1 |
06-28-2012, 06:09 PM | #15 |
Anyone know a good reliable and decent priced place to get parts for this quad? i have heard GARDNER INC (BAJA MOTORSPORTS), i bought my parts through SUPERSCOOTERPARTS.COM but was wondering if there were other places out there
