07-25-2016, 04:48 PM | #1 |
2005 NewStar 250
I have purchased a 2005 newstar ATV 250cc water cooled and am looking for parts it appears to have at least a blown head gasket seeing exhaust coming out from water inlet pipe and milkey oil I am looking for head gaskets possabibly a whole new head, piston, ring, cylinder assembly any one know a source for parts for this thing
07-25-2016, 07:07 PM | #2 |
Any pictures of that engine? What's the maker (The WMI ie. letters 1-3 of ViN ) / stamped cc & model http://www.mychinamoto.com/forums/sh...identification ... ?
07-25-2016, 08:05 PM | #3 |
Here are some photos numbers under the shifter are: 171FMM and *05A720526*
VIN starts with LHJ Last edited by Motohead; 07-25-2016 at 08:08 PM. Reason: clarification |
07-25-2016, 08:31 PM | #4 | |
07-25-2016, 09:59 PM | #5 |
LHJ = Bashan
Something weird in there. The barrel don't looks like typical water-cooled CG250 ... 71 What's that? The most common water cooled uses 67/69/70 (16mm pin) piston ... F = Air-cooled in theory
07-26-2016, 06:46 PM | #6 | |
171FMM that's the number Figures I would get some kind of oddball. any ideas on where to find parts |
07-26-2016, 09:46 PM | #7 |
As u said it's some oddball
171FMM maybe a lie... Measure it 1st. Barrel: height * width as http://www.mtctg.com/category.php?cid=5 | Piston: the Ø, pin Ø , compression height If matches a common 16mm pin model, u're saved from hellhole ...
07-27-2016, 10:39 AM | #8 | |
08-03-2016, 11:56 PM | #9 |
got it apart
Here is a photo with measurements the bottom left head bolt was not even finger tight causing the failure problem is the measurements everything I'm finding is 67mm
08-04-2016, 03:17 AM | #10 |
If you can't find the gasket you might have to go the route of a universal sheet gasket you cut to match. Metal shimstock possibly.. Not sure on this one.
08-04-2016, 10:00 AM | #11 | |
Yea its a 3 layer MLS gasket |
08-04-2016, 10:07 AM | #12 |
67mm water-cooled CG250 had 2 main types:
Lifan http://item.taobao.com/item.htm?id=524011100285 / Zongshen: http://item.taobao.com/item.htm?id=523998146869
08-04-2016, 04:52 PM | #13 |
Good find
08-04-2016, 04:59 PM | #14 |
If it helps any ....
https://translate.google.com/transla...romSite%3Dmain and https://translate.google.com/transla...3D523998146869 |
08-07-2016, 12:38 PM | #15 | |
