06-27-2015, 02:30 PM | #1 |
Clutch Help
I have a Sunl sla 110cc. My clutch is slipping how would i go about adjusting it and what is the location of it |
06-27-2015, 06:41 PM | #2 |
Is the clutch manual, semi auto or fully auto?
06-27-2015, 07:40 PM | #3 |
manual
06-27-2015, 08:41 PM | #4 |
Do you think its an issue with the clutch not engaging needing a cable adjustment or replacement or are the clutch plates worn and slipping?
06-27-2015, 09:51 PM | #5 |
gears are slipping, now when i hit the throttle it wont go if i hit it a few times then it does
06-27-2015, 10:30 PM | #6 |
You buy the clutch you need as a complete assembly. You also need a special clutch removal tool. Many people make this tool themselves but here it is. Just search YouTube for clutch replacement videos for the Honda horizontal engine. Also called a pit bike engine. A monkey bike engine. Or by cc 50cc, 70cc, 110cc. You do not need to remove the engine from the bike as long as you have access to the clutch cover case.
http://www.ebay.com/itm/CLUTCH-HUB-R...64fcb3&vxp=mtr http://www.ebay.com/itm/Manual-Clutc...item43dd7aa3ec |
06-27-2015, 10:46 PM | #7 |
I would also replace the cable. You need to remove and measure your existing cable and purchase an exact duplicate.
06-27-2015, 10:48 PM | #8 |
06-30-2015, 02:53 AM | #9 |
theres a plate on the right side of the motor...
clutch push rod ajuster is under it... check you have free play in the cable/lever... .
06-30-2015, 09:48 AM | #10 |
this site has great parts and a tech department you can call
http://www.outsidedistributing.com/C..._p/11-0109.htm |
