Old 10-01-2014, 10:28 PM   #1
trevorzstar   trevorzstar is offline
z-star master cylinder brake fluid eye indicator
Hello, I am looking for the glass or plastic brake fluid indicator eye for my zstar 110 quad. anyone know of any place inexpensive to purchase this. thanks trevor
Trevor
Old 10-02-2014, 01:01 AM   #2
brake reservoir
Hello.... you have to buy the whole piece... pm me about this... thanks
ABIBABA ATV ETC
Old 10-02-2014, 12:31 PM   #3
Mudflap   Mudflap is offline
When the window on my Lifan started leaking a couple years ago I glued a dime over it with JB Weld. Worked great and now my Lifan is worth 10 cents more!
Old 10-02-2014, 12:46 PM   #4
10 cents
that is a good fix as there is no pressure there... just needs to seal in the fluid.. I never thought of that... I wonder if crazy glue or Gorilla glue is ok with brake fluid???
ABIBABA ATV ETC
Old 10-02-2014, 09:51 PM   #5
I'd sooner use a two-part epoxy than glue. JB Weld or Permatex Cold Weld would be good choices.
Old 10-03-2014, 06:29 AM   #6
10 cents hey. did you have to drain the brake fluid and clean the resovoir so the jb weld would stick? I looked on line as well and they recommended also trying a freeze plug but couldn't find one that size roughly about 3/4 of inch in diameter. I found one place on the net where they sell the glass for $13. but 10 cents sounds even better. I also like adding value to things so this is for me.
Trevor
Old 10-03-2014, 08:16 AM   #7
I didn't have to take anything apart or drain the fluid. Just twisted the reservoir back on the handlebars so the window was more or less at the top, cleaned it up with soap and water, glued it on.
Old 10-03-2014, 11:00 AM   #8
I learned the hard way to not use brake cleaner on it. The overspray ruined the adjacent plastic. Soap and water is a much better idea.
For patriotic reasons, I'll use a Canadian dime.
Old 10-03-2014, 02:18 PM   #9
tortoise   tortoise is offline
Potential resource.
Old 10-04-2014, 10:11 AM   #10
Originally Posted by tortoise View Post
Potential resource.
Not bad! I might order one for a spare master cylinder I have.
Old 10-06-2014, 10:18 PM   #11
Brake reservoir
I see on EBAY the complete assemble from China is only $20.00... I would buy the complete assemble because my luck it would still leak alittle.. so for a couple of $$ more... buy the whole piece... I saw t hem for $15.00 for just the sight glass.. for $20.00 you get the handle as well
ABIBABA ATV ETC
