Old 02-21-2018, 03:53 PM   #1
TaoTao125   TaoTao125 is offline
Tao 125 carb leak
Hi all, it's my first post and i'll start with a question. I got a 2016 Tao Tao 125 today and when I turned on the fuel, gas starting leaking out of the carb. It stops when I turn the fuel on only halfway. I circled where it was coming from. Anyone know what causes this? Thanks much and look forward to hearing from you all!
Old 02-21-2018, 04:19 PM   #2
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
The bowl below where it’s coming out of fills up with gas and there is a float that rises with the gas. When the float reaches a certain height it stops gas from entering the bowl same as a toilet float works. Yours is most likely stuck and not rising with the gas and it’s coming out the overfill. You can try tapping it with a screwdriver handle and see if that dislodges it or open the bowl and fix it. A new carb is your best bet.
Old 02-21-2018, 07:31 PM   #3
Thanks so much for this info. Carbs are so cheap I should probably just replace it anyways. Never know with an unfamiliar atv. Thanks again!
Old 02-22-2018, 06:48 AM   #4
Al   Al is offline
I bought one off e bay for 12 dollars. Took two months to get here.
