Old 11-17-2015, 09:48 PM   #1
Tonyrader   Tonyrader is offline
Tonyrader's Avatar
I need Better chains and sprockets
My 250 e just spits the chain off when I get in it hard. I measured the side to side. I am square, I checked tension and chain tensioner, all seems good, but it just doesn't hold. My dads 250E does the same thing. I think they put 125cc chains and sprockets on it.. I don't know.. But I need good ones.
I don't care the cost, I want a good set of them... any Ideas? something Japanese...??? any Ideas???
Old 11-18-2015, 04:20 AM   #2
Mudflap   Mudflap is offline
It's possible the swing arm pivot bolt isn't tight enough. Put the nut end on the chain side and make it VERY TIGHT.
Old 11-18-2015, 09:39 AM   #3
Patrick4653   Patrick4653 is offline
This is a great site for parts. Check it out. I buy there all the time
http://www.outsidedistributing.com/default.asp
Old 11-18-2015, 08:06 PM   #4
Tonyrader's Avatar
That would be great if I could actually buy from them, I can look up the part. but then I have to go to the local dealer, and they don't even give me a price. so what is the advantage?? I can get a part number and then buy from ebay..that's nice..
Old 11-18-2015, 08:12 PM   #5
Tonyrader's Avatar
that is possible,, I will check that thanks
Old 11-22-2015, 02:36 PM   #6
ChinaATVMods   ChinaATVMods is offline
Whygostock can custom build sprocket for you for the rear. They have different size fronts in stock.
Email them with your specs and they will get back with you.
This is where we get our custom stuff for customers.
