12-02-2017, 01:20 AM | #61 |
Most of the new cup and cone ball bearing sets have nylon cages. They may or may not have a shorter service life because of this, but they work just fine. I am usually more concerned about the quality of the material with the ball bearings and the races than the cage.
Nice job on that repair too. It looks really good.
2018 Hawk 250 - Full Mod list here. http://www.chinariders.net/showpost....62&postcount=1 Hawk Information and Resource guide: http://www.chinariders.net/showthread.php?t=20331 2010 VFR1200F - http://chinariders.net/showthread.php?t=20708 |
12-02-2017, 09:54 AM | #62 | |
12-02-2017, 10:02 AM | #63 |
Thanks guys. I only snugged it up. I'll give it a second nudge after I ride it today. I did use marine grease.
Now waiting for my new carb manifold. Should be here monday.
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. |
12-02-2017, 04:00 PM | #64 |
The age old test for steering head bearings was to put a box under the crankcase high enough for the front wheel to clear the ground, then with the front wheel pointed straight ahead just give the 'bars a little nudge one way or tu other, and the whole front assembly flops over to the steering stop. Then go to the front wheel and try to shake it fore and aft. When you've got both conditions met, you've got the job done....ARH
12-02-2017, 04:12 PM | #65 |
Thanks. I had heard of that.
12-02-2017, 10:04 PM | #66 |
New carb manifold came today. I was hoping it would stop back sneezing thru the carb at idle. With some choke it clears up, and idles nice. The pilot is a 33. I i believe that means the pilot is a tad too small. I have the idle mix 2 turns out.
A 35 and 40 is on its way
12-03-2017, 12:36 PM | #67 | |
12-03-2017, 05:44 PM | #68 |
I have the float parralel to the body. I will check again though
12-03-2017, 08:53 PM | #69 |
You can also raise the float level, a hair at a time, and re-tune the idle adjustment leaner, if necessary. If you don't over do it, it will give a little "shot" of gas when you crack the throttle...ARH
12-04-2017, 10:36 PM | #70 |
I checked the float level with the clear tube method, and is about 5mm below the bowl flange. Should be good? Pilots are on the way. I have a 35, 38 and a 40 coming. It has a 33 now, and with the choke just barely engaged, im thinking the 35 will be the one. Im 2 turns out on the mix screw.
12-05-2017, 03:30 AM | #71 |
Do you get any light throttle stumble or hesitation?
12-05-2017, 08:52 AM | #72 |
With the choke engaged for smooth idle, it runs fine. If th choke is off, it back sneeze thru the carb. I have the valves set at .003 for both
12-05-2017, 09:08 AM | #73 |
Could you still have a tiny vacuum leak? I've had to squirt oil on the various parts/connections to find the leak before...ARH
12-05-2017, 02:09 PM | #74 |
I may. I’ll check with a unlit propane torch tonight
12-05-2017, 03:45 PM | #75 |
Do you have the stock air box or aftermarket pod filter?
If you have a pod filter, you might want to try and buy some kind of hose that fits your carb/filter to bring the filter away from the carb a bit, helps straighten/slow the airflow to get things working properly on some of the more picky engines/carbs
