Forum,
Does anybody know where I can find this at? We are having issues with the display and the handlebar switch will not start the atv. You can jump it from the solenoid and it runs fine. Also, where can you find the seat - ebay doesn't have it------- HHHHHEEEELLLLPPPP!!!!!!! ![]() ![]() ![]() LMSP |
Not sure where to get wire harness. Check all safety switches. Both hand brake and foot brake. Some will have a safety switch for neutral too.
I would try and see if you can clean out the switch .... I had the same issue on my TaoTao Rhino.... cleaned it out with a small wire brush and soaked it in WD40.... been working fine since.
I bought some replacement foot brake sensors.... they turn to junk too quick... just put a jumper on the connector and called it done. Got tired of switching them out every couple of months. For the seat you might be able to find a comparable TaoTao model that would be an exact fit... seems all these Chinese atv's for the most part pretty much use the same parts. |
