Old 09-11-2014, 01:03 AM   #451
Originally Posted by cheesy View Post
Thanks for the link; that's a really nice price.
Old 09-14-2014, 04:55 PM   #452
cheesy   cheesy is offline
cheesy's Avatar
Mrs. Fromage gives the new shocks a big thumbs up.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 09-14-2014, 05:38 PM   #453
It's always good to please the missus.
Old 09-14-2014, 11:50 PM   #454
Happy wife, happy motorcyclist.
Old 10-09-2014, 09:44 PM   #455
cheesy's Avatar
Ahhhh, the joys of owning a 35 year old Honda.
About ten days ago, I was riding home from work and decided to hammer it a bit. Shifted into 3rd at 60 and..........blew the end out of the left muffler. So, I got online and started looking for replacements. I found some repops offered up through David Silver Spares. However, at $130 a pop plus shipping, I was looking at $300+ for a pair.
Well, low and behold, HD Sporty mufflers are a pretty straight and recommended replacement for the Maggot mufflers. And they can usually be had cheap as long as you don't go through HD to get them. I found a pair on Craigslist for $20. Only real problem I have is that these came off of a later Sporty with a balance pipe and therefore have a couple of bungs I don't need.
So, into the horizontal band saw at the shop and Presto!!!, no more bungs.
A couple of 1 3/4" OD adapters, an oxy-acetelyne torch, a bit o' brazing rod and 15 minutes later.
I only had a limited amount of time(lunch)for government work today, so that's as far as I got. The piece of flat stock in the first pic is the new brackets. So, twenty for the cans, eight for the adapters, and four bucks for the steel. Even with my time, that's still a lot better than $300.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-09-2014, 10:41 PM   #456
I can't wait to see them mounted on the Honda.
Old 10-10-2014, 01:04 AM   #457
I've spotted similarly priced Sporty mufflers on the local CL, and I've often wondered what I could do with them. Nice job. Looking forward to hearing your impression of the sound. A vid would be terrific, if you have time.
Old 10-10-2014, 08:01 PM   #458
cheesy's Avatar
With a little luck, tomorrow.
One step closer.
I'm not married to the heat resistant paint. I may remove it down to the weld and leave it at that. That run is embarrassing, too.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-10-2014, 08:53 PM   #459
Mudflap   Mudflap is offline
Good to see some other CX fans on here. I put a pair of HD mufflers on my 80 CX and they sounded great, not too loud until you open the throttle. They were from a later model 1600cc and fit over the outside of the H box. I ride a 81 GL500 Interstate nowadays.
Old 10-10-2014, 10:58 PM   #460
cheesy's Avatar
Good to hear. The GL has the transistorized ignition, right?
The extensions I fit on the mufflers should just fit inside the Hbox. I might need to use the tailpipe expander just a bit. I'll know tomorrow.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-11-2014, 07:30 AM   #461
Yes the GL engine has transistorized ignition and a few other differences from the CX. Centrifugal spark advance, different cam profile, different rear engine cover, 1mm smaller carbs. That all gives it more power at the low end and less at the high end which is good for a touring bike. Won't run with a dead battery like the CX though.
Old 10-11-2014, 08:54 PM   #462
cheesy's Avatar
Well, no love today. I forgot that it was my turn to run down to the late FILs house to do the weekly yard work. That blew the better part of the day.
I did manage to get one muffler hung this afternoon but I had to throw out all the brackets I had made and start from scratch. Suffered from 'It looked good on paper' syndrome.
Hey, Mudflap. Did you have to rejet your carbs when you hung the Harley cans?
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-12-2014, 07:39 AM   #463
No need to rejet if you leave the H box in place.
Old 10-12-2014, 08:35 AM   #464
cheesy's Avatar
Kinda what I thought. Thanks.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 10-12-2014, 02:01 PM   #465
cheesy's Avatar
They are on. Video later, I'm going riding.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
