12-14-2015, 01:53 AM | #16 | |
it feels like a fuel problem, if i roll off to 1/2-3/4 throttle, i can rev it out more.... it WILL rev to about 8k i would guess (no tach), but i have to ease into it. |
12-14-2015, 02:11 AM | #17 | |
its been running great, and the weather had been good lately (FloridaLife). :-) was thinking about just jetting the pz30, now I'm just thinking about just going with the mikuni?!?!?!? |
12-14-2015, 02:14 AM | #18 | |
starting process is the same though... most definitely dependent on the temp... |
12-14-2015, 08:22 AM | #19 | |
could also be jetting related I suppose. |
12-14-2015, 10:11 AM | #20 |
CSR, maybe a 115 main jet is better in cold weather in your area.
Perhaps you could epoxy something to the head of the Philips screw, to make it easier to turn by hand, although a fatter slow jet might negate that need.
Weldangrind "I figure I'm well-prepared for coping with a bike that comes from the factory with unresolved issues and that rewards the self-reliant owner." - Buccaneer Last edited by Weldangrind; 12-16-2015 at 11:09 AM. |
12-16-2015, 08:41 AM | #21 |
Thanks for the advice, WeldAnGrind. I'll install 115 pilot and 140 main jets; open up the top of the air box; (like the 3x3 mod that's popular on DR-Z400s); then try using JB weld, fuel line as a mold, and silicone spray as a mold release on the 30mm clone's idle and mixture screws.
If that works I'll post photos and then transfer these ideas to the CVK32 carbs on my Ural. Maybe I can finally stop burning my fingers on hot Ural engine parts with each change in seasons (-: As many here have written, your knowledge, experience, and insight are both valued and appreciated.
The short list: 2011 Suzuki Boulevard C50T 2021 Chongqing Liyang Jiayu Hawk 250 DLX EFI 2017 TaoTao CY50-B scooter 79cc big bore kit - 45 MPH! (sold) 2015 Haosen Hawk (sold) 2002 Honda XR100R - project bike almost done. 2013 V-Strom 650 Adventure (sold )-: If I listed every bike that I've ever owned you'd either 1) Get bored 2) Be somewhat envious, or 3) Wonder: "What's wrong with that guy?" |
12-16-2015, 11:11 AM | #22 |
Sorry, I meant to say 115 main jet. I edited my post above.
You could also try a #40 slow jet, but I suspect that's a little fat. Where do you have the pilot mixture screw set?
12-16-2015, 02:00 PM | #23 |
Weldandgrind,
My mistake as well. I'm currently running a 35 pilot jet and 112.5 main jet. The idle mixture screw is backed out 2 turns. I've been thinking to open up the top of the airbox, so maybe I'll try that first. If I still get hard cold starts (I need to use electric starter unless I'm REALLY lucky), I'll install the #40 slow/idle/pilot jet that I have on hand. Thanks again for your help.
12-17-2015, 12:42 AM | #24 |
Opening up the top of the airbox will introduce more air, meaning the jets will be even leaner than needed. I recommend the fatter jets first.
