08-05-2016, 10:37 PM | #1 |
Wheel bearing ?
Hi I'm trying to find wheel bearings has any one found some for the hawk thanks
08-06-2016, 06:38 AM | #2 | |
or find the number on them..(ie 6204) go to a bearing surplyer or find them on line... bearing are very easy to work out when yer know how the numbering system works EG.. 6204 6 = type "in this case Deep groove ball race" 2 = OD.. comes in 3 & 4 04 = ID .. in this case is 20mm .. 10 = 50mm 09 = 45mm 08 = 40mm 07 = 35mm 06 = 30mm 05 = 25mm 04 = 20mm 03 = 17mm 02 = 15mm 01 = 12mm 2 , 3 , 4 OD sizes change with the ID size... type "6" Deep Groove is the most common type used on a motor bike... 1RS or 2RS at the end of the number = 1 or 2 Rubber Seals... pete ..
08-06-2016, 08:57 AM | #3 |
Don't know what's in ur bike. Take a peep of the # inside 1st...
--- Some knowledge about chinese bike: 白菜(Good old GY bike) F: 6301 | R: 6302 CQR (CRF clone/ From recent yrs...) F: 6202 | R: 6203
08-06-2016, 02:29 PM | #4 |
This is your opportunity to up-grade your axle/hub bearings. If Chinese ball bearings have a problem, I doubt it is the metallurgy. More likely the grease quality has not yet caught up to the rest of the world. And the rubber in the seals are suspect as well.
08-06-2016, 03:59 PM | #5 |
Hawks have different wheels than the TT250, but, maybe the same bearings.
http://www.cscmotorcycles.com/TT250-...EELS-s/364.htm |
08-07-2016, 10:39 AM | #6 |
Thanks
08-07-2016, 03:38 PM | #7 |
OK, but why not take one of the front wheel, and one of the rear wheel bearings to anybody who sells bearings and seals, and find an American/Japanese/English/German/Italian replacement. Wheel bearings should last the life of the machine.
