01-31-2018, 03:20 PM | #46 |
How much lube are you talking about? just a light coat on top the piston or like a real heavy layer?
01-31-2018, 03:25 PM | #47 |
I used assembly lube which is basically a grease thats suppose to dissolve after you run it. Its a bit thicker then oil but I just put a coat on the cylinder wall and valves when I installed everything
01-31-2018, 03:33 PM | #48 |
200 psi seem high. should be around 175-180 psi. Did you measure the distance from the pin to top of piston to see if it was the same as the old piston?
01-31-2018, 03:36 PM | #49 |
Yes I measured the two and they were identical
01-31-2018, 03:45 PM | #50 |
May be the assembly lube does have something to do with it. I know you didn't take that much off the head cleaning it. lol Hopefully it's just your gauge is off.
01-31-2018, 03:58 PM | #51 |
Quite possible. Thick oil like assembly lube will stick and seal things up a little better. 200psi wouldn't alarm me at all on a fresh overhaul if I knew everything else was correct/set properly. Nice strong number.
01-31-2018, 04:00 PM | #52 |
Lets fire that baby up!
02-01-2018, 10:11 AM | #55 |
Did you have the throttle open or closed during the compression test?
02-01-2018, 10:13 AM | #56 |
I didnt have the carb on. I Just bolted the head on and did the compression test with open intake and exhaust
02-01-2018, 10:59 AM | #57 |
That makes a difference. Imagine having the intake tube and carb installed with the throttle closed on the carb. It would draw very little air in that case, resulting in lower numbers. A wide open throttle (or in your case, no carb) allows the cylinder to grab as much air as will fill it. No exhaust also means that there is no back-pressure restriction, which also allows the cylinder to fill more completely. I think 200psi with no carb or exhaust sounds like a good number.
02-02-2018, 12:42 PM | #58 |
Well Today I got the motor back installed on the Hawk. Bolted everything except for the exhaust because I wanted to make sure it ran before I put it all back together. It didnt start at first but after some convincing i got it to start and idle. The video is below. The only issue is when I give it any throttle at all it dies. Im assuming its a carburetor issue that ill have to look at later but thats the update for now!
02-02-2018, 01:22 PM | #59 |
Sounds good. Once you have the exhaust and air box connected it should run better. Engine probably died because it hasn't warmed up enough.
02-02-2018, 02:24 PM | #60 |
Put the exhaust on and then try to run it before assuming a carb problem. No exhaust at all will throw off the carb tuning, and it won't want to idle or run correctly.
