Old 01-31-2018, 03:20 PM   #46
Originally Posted by zach3697 View Post
After I torqued all the bolts down im getting 200 psi compression. Could it be so high from the assembly lube?
Thanks!
How much lube are you talking about? just a light coat on top the piston or like a real heavy layer?
2020 Kawasaki Vulcan S
Old 01-31-2018, 03:25 PM   #47
zach3697   zach3697 is offline
I used assembly lube which is basically a grease thats suppose to dissolve after you run it. Its a bit thicker then oil but I just put a coat on the cylinder wall and valves when I installed everything
Old 01-31-2018, 03:33 PM   #48
200 psi seem high. should be around 175-180 psi. Did you measure the distance from the pin to top of piston to see if it was the same as the old piston?
Old 01-31-2018, 03:36 PM   #49
200 psi is high seem high. should be around 175-180 psi. Did you measure the distance from the pin to top of piston to see if it was the same as the old piston?
Yes I measured the two and they were identical
Old 01-31-2018, 03:45 PM   #50
May be the assembly lube does have something to do with it. I know you didn't take that much off the head cleaning it. lol Hopefully it's just your gauge is off.
Old 01-31-2018, 03:58 PM   #51
Thanks!
Quite possible. Thick oil like assembly lube will stick and seal things up a little better. 200psi wouldn't alarm me at all on a fresh overhaul if I knew everything else was correct/set properly. Nice strong number.
Old 01-31-2018, 04:00 PM   #52
Lets fire that baby up!
Old 01-31-2018, 04:07 PM   #53
Haha exactly what I plan on doing. At work right now but I'm going to try tomorrow to get the motor in and fire it up!
Old 01-31-2018, 04:21 PM   #54
bogieboy's Avatar
Agreed with Megadan.... 200 is good with grease/lube... when i did a new piston in my 200 without grease style lube (just motor oil) i saw 190....
Old 02-01-2018, 10:11 AM   #55
Did you have the throttle open or closed during the compression test?
Old 02-01-2018, 10:13 AM   #56
I didnt have the carb on. I Just bolted the head on and did the compression test with open intake and exhaust
Old 02-01-2018, 10:59 AM   #57
That makes a difference. Imagine having the intake tube and carb installed with the throttle closed on the carb. It would draw very little air in that case, resulting in lower numbers. A wide open throttle (or in your case, no carb) allows the cylinder to grab as much air as will fill it. No exhaust also means that there is no back-pressure restriction, which also allows the cylinder to fill more completely. I think 200psi with no carb or exhaust sounds like a good number.
Old 02-02-2018, 12:42 PM   #58
Well Today I got the motor back installed on the Hawk. Bolted everything except for the exhaust because I wanted to make sure it ran before I put it all back together. It didnt start at first but after some convincing i got it to start and idle. The video is below. The only issue is when I give it any throttle at all it dies. Im assuming its a carburetor issue that ill have to look at later but thats the update for now!
Old 02-02-2018, 01:22 PM   #59
Sounds good. Once you have the exhaust and air box connected it should run better. Engine probably died because it hasn't warmed up enough.
Old 02-02-2018, 02:24 PM   #60
Put the exhaust on and then try to run it before assuming a carb problem. No exhaust at all will throw off the carb tuning, and it won't want to idle or run correctly.
