Old 06-23-2015, 04:54 PM   #556
Thanks for letting us know he is well, Allen.
Old 06-28-2015, 05:57 PM   #557
cheesy   cheesy is online now
cheesy's Avatar
Yes. I miss the youngster.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 06-29-2015, 11:39 AM   #558
As do I.
Old 07-09-2015, 10:47 PM   #559
cheesy's Avatar
Well, poop. Riding has been somewhat curtailed for the next few weeks. Besides going back on the road again, the stator on the CX is going through it's death throes. All the problems I THOUGHT I was having with carbs were the low speed coil going south. I can still ride the bike to the office for a bit, the missing and sputtering problem doesn't show up until the engine gets good and warm. But long rides are done for the time being.
There is an up side to all this. I called Custom Rewind(highly recommended, BTW) down in Alabama today and spoke with the owner. Because I actually have another stator(toasted)out of the bike that I can use as a core and because he doesn't move many of the OEM G47 stators anymore, he cut me a heck of a deal on a new one.
Now the real downside. I need to drop and split the engine to replace the stator. Just a little weekend project.
Smart money would insist on replacing the R&R, too. Then I'll have an entirely new electrical system.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-10-2015, 01:14 AM   #560
How much does a typical reg/rec normally cost?
Old 07-10-2015, 08:36 AM   #561
cheesy's Avatar
Anywhere from $15 to $200. Either of those choices is a bad move. I'm springing for this MOSFET unit.
http://motoelectrixcom.myshopify.com...-rectifier-kit
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-10-2015, 02:10 PM   #562
It's too bad you need to split the crankcase to replace the regulator/rectifier. I have never heard of that situation before.
Old 07-10-2015, 03:12 PM   #563
katoranger's Avatar
Its due to the longitudinal layout of the CX engines.
Old 07-10-2015, 04:05 PM   #564
cheesy's Avatar
Splitting the case is probably a misnomer, I'm removing the rear cover. That is still part of the crankcase, tho. Also houses the water pump, starter, gear shift and output shaft.
The stator is that funky brown thing. Either the coil with the metal plate or the one directly opposite it is the culprit. The actual replacement will only take about an hour. Six to eight for everything else. I'm taking a couple vacation days next month to do it.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-10-2015, 04:23 PM   #565
Now I understand. You need to remove a crankcase cover to replace the stator, not the regulator/rectifier. On my bikes I can replace the stator by removing the left crankcase cover. However, because of the longitudinal orientation of the CX500 engine, the engine must be dropped, and a rear crankcase cover must be removed.
Old 07-10-2015, 08:40 PM   #566
cheesy's Avatar
Bingo, Spud. I should have read that a bit closer. As to the reg/rec, piece o' cake. I just need to pull the left side cover to access that.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-10-2015, 09:41 PM   #567
The old Goldwings have the same layout for the stator, engine must be dropped to remove back cover for access. Common malady on the old wings as well. That's why so many people just do the alternator conversions on them. Although ultimately I'm guessing it would take about the same amount of time for the conversion as dropping the motor and replacing the stator. I guess they are "future proofing" it though.
Old 07-11-2015, 06:35 AM   #568
cheesy's Avatar
I've seen that conversion and keeping it tucked in the dusty cabinet file of my mind just in case I do end up with an old 'wing someday(Mrs. C is starting to soften). It's too bad that something like that isn't possible with the CX without a total redesign of the cooling system and frame. Just too compact of a package.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-11-2015, 12:21 PM   #569
Had the engine out on my CX500 Custom once, did it myself as well and I recall it being a little awkward to set down once I got it out... Lol, I didn't have much in the way of tools or jacks back then though, and I did it in a parking lot. I sold my old GL1200 this spring dirt cheap, kind of regretting it now, it sure was a nice highway bike!
Old 07-14-2015, 01:10 PM   #570
cheesy's Avatar
Stator is on it's way. Unfortunately, I may not have time to swap it out until Labor Day Weekend now. This working for a living sure has some downsides.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
