Old 04-28-2017, 03:30 AM   #1
Tonnyguy   Tonnyguy is offline
Doh! Vader 125cc 2016 bd125-15
Hay ! Was looking for this kind of forum for days !!
I just got my vader 125cc 2016 ,
Very nice bike run very nice but !! Cupale problem I'm going crazy with ,
The battery die ! I cnot turn the bike on with the electric only with push , what can be this problem and I read that it's very popular problem and fixble so maybe someone know how to make it work
Which cdi I can buy for it how many pins ?
What the best carburetor I should use to upgrade the bike ?
Oil ? 10w 40?
It is ok to use 91premume gas?
What more can I change to make it go faster ?
Thanks so much for who going to help me !!
Old 04-28-2017, 08:28 AM   #2
PhildoScaggins   PhildoScaggins is offline
Hey Tonnyguy! welcome to the club. I just got my vader running good yesterday. The stock headlight bulbs draw to much and kill the battery. I replaced mine with these
https://www.amazon.com/gp/product/B00D6PJGJM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Also my carb had the throttle screw backed way out, and made it so that my electric start wouldn't work and the bike wouldn't idle.
I think used wet clutch safe 10w-30 for oil. Change every 100 miles or so for the break in period.
Always use premium gas!
As for faster a lot of people are switching their carbs to a mikuni 26mm vm22.
Doing a sprocket change will get you a bit more in top speed, but slow your acceleration. 15t or 16t is common.
Old 04-30-2017, 04:45 AM   #3
Vader 125cc
Ok thanks about that.
What I find out when look up online that
428 17t front sparked is the right one .
About the oil I understand that 10w 40 is the best you really think 10w30 will be better?
About the carburetor do I need to tune it and play with that or I can buy it and just replace it with the old one ?
What about the cylinder there is any cheap option about that ??
Cdi box not will make change ?
Thanks!!
Old 07-19-2017, 11:14 PM   #4
martim   martim is offline
Thumbs Up Exhaust Recommendation for 125CC
Any recommendations on exhaust upgrade and carb upgrade for this bike?
Thanks,
Old 08-12-2017, 05:10 PM   #5
Shadytech   Shadytech is offline
Thanks,
I have installed a VM22 carb along with a 26mm intake manifold to my BOOM BD125. I have it pointing forward and it only requires slight modification to the plastic under the red frame.
For exhaust I went with the Aodonly Racing exhaust. It fits but you'll have the bend the pipe right under the engine at the 90 degree bend.
