05-09-2018, 12:44 PM | #1 |
I use the same type on my Quad with the CG engine. The radiator gets very hot so it must do some cooling. Looks to me like the type that attaches to the oil screen port sucks the oil through which in case of a leak would be pumping air instead of oil. Maybe someone will correct me if I'm wrong.
05-18-2018, 06:04 PM | #2 |
anyone have a source for the oil screen adapter one?
05-18-2018, 06:41 PM | #3 |
05-19-2018, 06:21 PM | #4 | |
you are not wrong... sucking the oil though those lines and cooler before it gets to the pump.. ..
05-21-2018, 10:17 AM | #5 |
Then at a minimum I would want a low oil pressure warning light to be used with the oil screen type cooler.
