Old 02-10-2016, 09:06 AM   #1
853am   853am is offline
CF Moto V3 crankcase
Hello,
New guy here. I'm rebuilding a 2004 V3 and the left side crankcase is missing a piece of the fin/baffle that is located under the crankshaft. Anyone have any experience or advice on how to proceed?
Option 1: put it back together and don't worry
Option 2: wait until a used one becomes available on the market
Option 3: have a new fin welded or bolted in
Option 4: modify a CN250 crankcase w/the existing V3 crankcase
This is my last hurdle, any thoughts would be appreciated.
Thanks!
Rich
Old 02-10-2016, 10:50 AM   #2
Welcome, Rich!
Please show us a pic. Perhaps we can find something else that is a match.
Old 02-10-2016, 01:30 PM   #3
This is a pic of the left side crankcase. You can see the missing piece (jagged edge.) Am I worried about nothing?
(Second pic is stock photo of right side crankcase. You can see the baffle/fin in it's entirety.
Thx,
Rich
Old 02-10-2016, 01:31 PM   #4
Sorry, this left side
Old 02-10-2016, 11:58 PM   #5
I'm failing to see the jagged piece, and I'm blaming that on my crummy monitor. Can you put a circle around it?
Old 02-11-2016, 03:43 PM   #6
better?
Old 02-12-2016, 10:54 AM   #7
Yes, I see it now.
I wouldn't hesitate to smooth out the area with a Dremel, apply Three Bond (or similar) as a liquid gasket material to what is left of the gasket surface and use it.
Old 02-18-2016, 02:41 PM   #8
Okay, got the crankcase together. Any idea what parts #5 & 6 do?
Kept coming out on the last build.
Old 02-22-2016, 09:23 PM   #9
Not looking familiar to me. May we see a pic of how they attach and what they look like?
Old 02-25-2016, 12:43 PM   #10
bogieboy's Avatar
hey weld that wouldn't be a centrifugal oil filter like on the Cg engines would it?
Old 02-25-2016, 06:51 PM   #11
humanbeing's Avatar
5|0010-040011-0050|油道接头 |joint, oil passage
6|0010-040010 |油道接头弹簧|spring
#5 in honda ancestor is 15441-149-000 . Ref to that # , u can guess how it works...
Old 02-26-2016, 11:06 AM   #12
I'm still not quite there, but at least I can now see we're not looking at the stator side.
Old 03-04-2016, 03:22 PM   #13
There's no bar on the new crankshaft for it to grab onto, so I'm going to leave it off. Honda shop manual calls it an oil orifice.
Can anyone tell me how me how to tighten the flywheel? The variator is also off if that helps.
(When I was dis-assembling, the rod had come loose and prevented the crankshaft from turning, so I didn't have these issues.)
Thanks!
