10-26-2016, 11:46 AM | #1 |
I like the headlight as well.
The kicker shaft has a groove machined into it, and the kicker should slide on far enough that the bolt rests in the machined groove. As long as the bolt doesn't fall out, the kicker will never slide off.
10-26-2016, 12:42 PM | #2 |
Ah okay. Good to know. I'll get it out on there tonight
10-26-2016, 03:40 PM | #3 | |
It should be noted the bolt needs to be removed to slide it in place...sounds like that is what may be the problem here. Remove bolt. slide it on..replace bolt so it sits in said groove.
Past bikes: '10 Gio X33 '85 Honda VF750F Interceptor '80 Honda XL185S '76 Yamaha DT250C dual sport Baja Wilderness Trail 250 '07 Honda Shadow 750 Areo Trike '01 Harley Davidson Softail Deuce Polaris Magnum 425 4x4 Quote:
