Old 04-25-2014, 06:34 PM   #1
weiser23   weiser23 is offline
rear sprocket
my bike suddenly stopped I hit gas the rpms went up but nothing I tried pushing the bike and it bound up I thought the transmission went out but looked down to find a bolt here all the bolts broke off the sprocket ,I left my bike and went home two bolt were at my house 2 mile away im not sure why this would happen and what to do about it
Old 04-25-2014, 07:14 PM   #2
stretch8668   stretch8668 is offline
Did they just back out or shear off
Old 04-25-2014, 08:18 PM   #3
They all sheard off ..I felt no sign of problems
Old 04-26-2014, 02:15 AM   #4
The rear bolts are typically studs that are simply placed in bushings in the rear hub. It provides a cush drive effect, to take up the shock load.
The answer is to buy Honda studs, which are higher quality. Like these (item 13): http://www.bikebandit.com/houseofmot...m2988#sch20077
It also wouldn't be a bad idea to replace the bushings.
Old 04-26-2014, 05:24 AM   #5
so I don't have to worry if I cant back those broken bolts out I can replace the bushing ... and how is that done
Old 04-26-2014, 09:17 AM   #6
katoranger's Avatar
Those studs bolt to the sprocket and they just slide into the rubber bushings. There is a big circlip that holds the sprocket to the hub. Most difficult thing is the big circlip.
I have not heard of anyone shearing off the honda studs.
Old 04-26-2014, 09:40 AM   #7
Sorry I should have said this is a 09 qlink xp
Old 04-26-2014, 11:50 AM   #8
That changes things. Perhaps someone with Q knowledge will chime in.
Old 04-27-2014, 07:09 PM   #9
didn't take wheel off yet but it looks like the bolts screw right into the wheel I hope the threads are not messed up a new wheel is $350 or more
Old 04-30-2014, 08:59 PM   #10
the mechanic I use from time to time has access to a machine shop and he going to drill them out ,, put new bolts in for less than $100 that's 1/4 of a new rim tire change that I thought for sure was going to happen
