10-04-2014, 08:57 PM | #16 |
To keep the stem straight for welding I found a tube in my junk metal pile that fit snugly inside.
No need for an analog speedo, the bicycle speedos work great. I have them on all my bikes. |
10-05-2014, 12:21 PM | #17 |
I've used a bicycle speedo before as well, but I failed to buy one that is back-lit. I also struggled on my ATV, because the wire was so fine, it was easily damaged. The magnet was also a challenge. What kind of magnet did you use?
10-05-2014, 12:59 PM | #18 |
The ones I use aren't backlit either but I rarely ride after dark. On the rare occasion I do ride after dark I use a backlit GPS for a speedo. The sensor wire is indeed tiny and easy to damage so I zip tie it to the front brake hose or cable. I've also seen wireless units but haven't tried one. The magnet supplied with the bike speedo works fine. I goop it up with liquid electrical tape to keep it from moving.
