Old 05-25-2016, 11:41 PM   #76
Originally Posted by Darth Racer View Post
Messed around with the mill tonight.... made a shift indicator panel out of some junk delrin. Have to mess around with the spacing but you get the idea. Debating putting some glow in the dark paint in the numbers
If that just messing around, I wonder about when you give a dam!
Old 05-26-2016, 10:43 PM   #77
Darth Racer's Avatar
Thanks..... all I can say to that is stay tuned
Old 05-27-2016, 10:22 AM   #78
That looks cool! My only concern would be now that I've had my Rhino out blasting around some rough trails, with the AWESOME suspension these have, you may be too busy hanging on for dear life to these "bucking rhinos" to be able to glance down to see what gear you're in! LOL!
Old 05-27-2016, 07:52 PM   #79
Thanks
LOL .. the indicator is more for when I'm starting up.... wont be tearing around in the Rhino too much. Just hauling gear at tractor speeds for the most part.
Old 05-31-2016, 11:26 AM   #80
evanb143   evanb143 is offline
Chain noise???
I am sure this has been talked about but can't find it. I just bought a Rhino 250. After about a week of riding there started to be a noise like values knocking. Having a friend walk next to me he said it was the chain. It only makes noise at low speed when first taking off or if I up shift to fast like it is rattling. The chain is tight so that is not the problem. Is this normal?? Could it be chain is to tight? Bought it put together by shop and they stated they made it tight for stretching.
Old 05-31-2016, 12:48 PM   #81
My chain was WAY too tight out of box. Adjust that and also, if you haven't yet, change the oil. The stock stuff is garbage. It only takes a quart. Cheap insurance.
Old 05-31-2016, 01:50 PM   #82
They did first oil change for me!! Very nice. I called and they said to check all 4 bolts for axel and that chain is running strait. I will also loosen it a little bit.
Old 06-18-2016, 03:38 PM   #83
Update, found out chain was to loose (dumbass), problem fixed. Was funny though had to cut nut of tension bolt left side. Was stripped in middle of bolt!! Never hand that happen before. Found bigger nut to fit it. Took out with friend on his brand new can am ($8000) lol. Top speed was 38 mph.
Old 06-18-2016, 05:17 PM   #84
Glad you got to take it out! So you had the joy like I did with my buddy on his Honda TRX 450. You get used to yelling..."You go ahead! I'll catch up!" ;-)
For the drawbacks, it's really hard to beat these for the $$$.
Old 06-20-2016, 05:41 PM   #85
Yes we rode about 6 miles around my land He was nice enough to wait. And hell yes can't beat the price.
Old 06-26-2016, 12:17 AM   #86
Governor
Is there another governor some where on or in the carburetor to adjust on the 250, other than the screw on throttle?
Old 06-27-2016, 10:48 AM   #87
Everything on my stock carb was sealed up. Even the slide was red loc-tited. Unreal. I tossed it and got the Mikuni.
Old 07-13-2016, 10:03 PM   #88
Just got done with the sprocket mods on my Rhino will post pics tomorrow.
37t rear and 11t front. Did the axle hub stop mod while I had everything apart too.
Old 07-14-2016, 06:57 AM   #89
Are you making it faster??
Old 07-14-2016, 10:13 AM   #90
Right on! I'll take any info I can get. I'll have to sneak in a rear sprocket order with all of Mrs 2LZ TT stuff! ;-)
She'll never notice..........
