05-27-2018, 01:20 PM | #1 |
is the idle mixture screw on the side? I thought it was on the bottom like the pz30.
05-27-2018, 01:30 PM | #2 | |
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
05-27-2018, 01:34 PM | #3 | |
05-27-2018, 01:39 PM | #4 |
Yes the screw that is shielded by an impossible to remove domed brass plug. I tried to drill it I tried to use a punch and nothing would budge it so the idle speed mixture stayed stock and I just adjusted the needle and changed the main to a 115 and left it at that.
