10-27-2016, 03:46 PM | #1 |
Why 17/45 Sprockets on Hawk 250?
Why are the majority of the Hawk owners going with 17/45 sprockets (2.65)? Why not 15/40(2.67)? It will be close to the same ratio and would only need to change the rear sprocket. I know I would have to cut the chain but that's easy stuff. This would shorten the chain by 2 links. Shorter chain less stretching. The 45 tooth sprockets are $25 and not in stock but I can get a 40 tooth for under $19. Has anyone done this combo with any issues? Just think outside the box.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-18-2017 at 03:55 PM. |
10-27-2016, 05:33 PM | #2 |
I'm running 16/40 combo that's been working well for me.
10-27-2016, 05:45 PM | #3 |
That's good to know, so I should be ok with 15/40. I could always do the 16t on front if I feel the need to.
10-27-2016, 06:02 PM | #4 | |
10-27-2016, 08:24 PM | #5 |
A new chain is in the plan once I change the sprocket and I'm satisfied with the setup.
10-28-2016, 01:22 AM | #6 |
Why not try it? What is the worse that could happen?
10-28-2016, 06:31 AM | #7 |
Ordering the 40t today. I knew the sprocket would work. I was just concerned if anyone had any issues with the combination of the 15/40 sprockets. I'm still waiting on my jets. They're on that slow boat from China.
10-28-2016, 09:46 AM | #8 |
What is your top speed with this setup? Do you lose any low end for off-road? I may just order the 16t to try it out.
10-29-2016, 08:11 AM | #9 |
I've thought about this as well. I'm currently running a 17/45 and have toyed with the idea of going to a 17/43???
If I were to do it again, I think perhaps a 16/43 (2.69) may be the sweet spot to start. Easier and cheaper to change the front if you want to make further changes, dropping all the way down to a 40 rear seems extreme to me, and a 43 rear leaves you options of adjusting the front to a 15, 16, or 17? Is a 14 front available, or too small IDK... |
10-29-2016, 03:27 PM | #10 | |
10-31-2016, 01:52 PM | #11 |
My top speed with the 16/40 combo is still only around 70-75 mph depending on the incline and wind. Just not enough power to pull high speeds consistently. I don't ride off road with the Hawk too much but for easy trails it works well for me.
10-31-2016, 02:46 PM | #12 |
According to my tracking # i'll get my 40t tomorrow. I think the 15/40 will work out perfect but good to know that the 16/40 combo works. I'm about 50/50 on and off road and the off road is mostly flat with only a few man made hills. No hills in South Louisiana lol. The Corp of engineers have set up a great off road area in the Bonnet Carre Spillway in Norco , La. with about 5.5 - 6 miles of trails.
10-31-2016, 03:11 PM | #13 |
O-ring chain
Has anyone tried this chain? XFMT Gold Oil-Sealed Custom O-Ring Heavy Duty Drive 428 x 136 Chain https://www.amazon.com/dp/B019OEZFKW...I20PBHCDVW0MML Not a bad price.
10-31-2016, 09:14 PM | #14 |
11-01-2016, 08:00 AM | #15 | |
