04-10-2012, 12:16 AM | #1 |
trailer re-do
so I figure that wile I have the extra coin it is time to redo the deck on the trailer and it seemed like a good day to start on it.
trailer before tearing the triple layer plywood deck off....this was completely saturated with water all the way through. was planning on cutting the V front off but decided to keep it on as a deflector. tore off the top layer and found a new life form developing a society within here is the frame stripped down cut off all the old stove bolts and gave it a quick scrape with the grinder going to scrape it a bit more to get scale off then tremclad clean over the steel and lay in some good decking with tie downs inserted flush with the deck.
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
