02-12-2019, 02:30 PM | #1 |
Compression Ratio for a 125 CC ?
What should the Compression be for a 125 CC ATV
02-12-2019, 11:39 PM | #2 |
My guess is that 130 is a good number. Are you having running problems?
02-13-2019, 09:26 AM | #3 |
Should be around 145-170 psi. If you think it has low compression it may just be that the valves are to tight and need adjusting.
Here's a link to a service manual. http://www.google.com/url?sa=t&rct=j...Sbkg3xQw6Y2pZ7
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-13-2019 at 11:08 AM. |
