09-11-2012, 03:03 PM | #16 |
Two different terms are being used here. If you puchase a rim, you'll need to lace it to your hub and true it. If you buy a wheel, it is a hub and rim assembly that will most likely be true, although I'd check it.
09-11-2012, 03:07 PM | #17 |
Check some more bike shops. I know the one I frequented in college also did alot of motorcycle wheels.
09-11-2012, 03:07 PM | #18 | |
so it will probably be pretty aligned and true, cool, ill wait for more replys, If the full wheel comes trued ill probably just buy one, for $110 off roketa
2021 Boom Vader Gen 2 BD125-10 Current 2011 DRZ400S Current 2006 LIFANIZED ROKETA DB-06 200cc Sold 2008 Ninja 250R Sold 1984 Honda aero 125 Sold 1980 Honda CM400T Sold |
09-11-2012, 03:09 PM | #19 | |
09-11-2012, 03:11 PM | #20 |
Same process. Doesn't matter the size of wheel.
09-11-2012, 04:17 PM | #21 |
okay
well we'll see if that guy gets back to me, all else fails, ill buy a whole new wheel assembly, witch at this point, seems like an easy way out of this problem. seeing as i can't find people to work on it atm.
09-11-2012, 10:54 PM | #22 | |
09-11-2012, 11:13 PM | #23 |
truing wheels isn't all that hard.
watch this your forks make a good truing stand, jack up the bike in some way that the front wheel is off the ground. I like to use a com a along attached to the handlebars. then just get two zipties and tape them to the fork tubes pointing towards the rim about 1mm off of it in the most neutral state of the wobble. then true as shown in the video. Also it is possible to true rims with a small adjustable wrench, but is about 10 times as fast to use a spoke wrench of the correct size :wink:
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470 400cc lifan build vid: http://youtu.be/20HoU8OK_Y0 other fun: http://tinyurl.com/wildalaskan |
09-12-2012, 01:19 PM | #24 | |
Worst comes to worse ill have to drop another hundy on the new wheel assembly, what im afraid of though, is ill buy the wheel assembly and they'll give it to me not assembled, Not sure if that's likely , but i have no idea. thanks
09-12-2012, 10:17 PM | #25 |
A wheel should come assembled
09-13-2012, 01:34 AM | #26 |
I have bought several front wheel assemblies from Roketa. The wheels came fully assembled with bearings, and were trued to a high standard.
09-13-2012, 01:26 PM | #27 | |
I'm going to try truing using WA's suggested method either today or tomorrow. are bicycle spokes the same size as dirt bikes? i want to see about getting a spoke wrench, going to hit up a bicycle shop and see if they have one if they're the same size.
09-13-2012, 01:44 PM | #28 |
You'll need a motorcycle wrench. In a pinch an adjustable wrench or small spanner will work.
Just don't let a 'real' mechanic see you with an adjustable wrench. The spoke wrench sold by Tusk broke on me second or third time I used it. You may want to order a Motion Pro or similar higher quality one.
Happy to serve. |
09-13-2012, 03:22 PM | #29 |
I bought one at a local dirt bike shop. Think its the motion pro brand.
Motorcycle spokes are much larger.
09-14-2012, 12:53 AM | #30 | ||
http://www.roketa.com/product/parts_detail.jsp?partId=31846&partName=STEERING%20 ASSEMBLY(5) I have Honda, Motion Pro, and Tusk spoke wrenches. All of them work well. The Tusk spoke wrench is very sturdy, and I doubt I could break it if I tried. http://www.rockymountainatvmc.com/p/...k+spoke+wrench Spud
