10-23-2017, 09:05 AM | #4 |
I've thought about doing this myself. By advancing the timing you may lose some low end power but will increase top end. At the same time you will have to run a higher octane fuel to compensate for the higher timing. But the correct way to do this is to get a programmable CDI to that you can keep the time where it is now in the lower rpm and increase timing in the higher rpm range. Like this http://www.dansgaragetalk.com/topic/...-time-mapping/
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-23-2017 at 10:45 AM. |
