09-06-2015, 10:03 AM | #1 |
Cross ref to japan chain and sprockets
I have the 428 chain and sprockets and My rear sprocket is not machined deep enough to hold when I drop the clutch hard. I have it as square and tight as I dare, but I am 187# and it will cat walk pretty good, but you can hear the chain jump the rear sprocket. Is this a common problem?
09-06-2015, 11:44 AM | #2 |
Make sure the swing arm pivot bolt is VERY TIGHT.
09-06-2015, 06:10 PM | #3 |
Ok that makes sence. Like if it cocks sideways, it would make the chain out of alinement.
I will check that.. I got two days before I have to leave.. |
