Old 03-26-2008, 12:25 PM   #1
bronevaya   bronevaya is offline
carb help!!
so I finally took the carb apart last night, found some shit in the bowl, cleaned it out, and put it back together.
but now when I turn the gas on the carb floods and spills over. also the throttle cable has some slack and turning the bike on will make it flood/rev real high. I think I installed that little tube the needle sits in wrong. how is it supposed to go? I dont think mine goes to the very bottom. also my needle was set to the highest point.
how far down should the slide thing go?
Old 03-26-2008, 01:19 PM   #2
PorterzCustomz   PorterzCustomz is offline
Send a message via AIM to PorterzCustomz
Re: carb help!!
Originally Posted by bronevaya
so I finally took the carb apart last night, found some sh-- in the bowl, cleaned it out, and put it back together.
needle should be near bottom for stock. Something in the carb is stuck you may have put something back wrong or the float came off the hinge. Pull it apart again reclean the whole carb (not just the bowel) and make sure it goes back together correctly.
Old 03-26-2008, 01:27 PM   #3
after looking at this
http://www.chinariders.net/gallery2/...serialNumber=2
I think I put in #4 in wrong :(
AJSFHKJASDHK:JASHDKJASHDKJHASDLK WHAT A PAIN!!!!!!
because of the throttle cable its such a bitch to get that part out :(
Old 03-26-2008, 01:38 PM   #4
AZ200cc   AZ200cc is offline
You're going to get good at taking that carb off
Sucks when things like that happen...I usually wind up doing everything twice.
