Old 03-25-2008, 04:28 PM   #1
bronevaya   bronevaya is offline
mounting holes/brackets cracking/falling off
pfffffttt, damn shoddy welding.
so some of the motor mounts are cracking and one is only held on by the tightness of the screw (will have to take pics later)
what options do I have? re-weld?
Old 03-25-2008, 04:50 PM   #2
Warrranty ???
If not just clean it up, reweld and repaint.
Old 03-25-2008, 04:51 PM   #3
The fix I did was to put an oversized washer under the nut and weld the remaining bracket to the oversized washer. Seems to be doing ok now. Not sure why the mounting bracket broke, but my guess is the push rod engine produces more vibes and torque on the frame than the OHC that I have. If you do this, be sure to sheild the tank and carb while you are welding. I had to use an arc weld and stick to get in there and do mine. I did not remove anything from the bike.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 03-25-2008, 05:00 PM   #4
I must be a wimp because I wont even think of welding with fuel closer than 15 feet of the project.
Old 03-26-2008, 02:40 AM   #5
liverchip   liverchip is offline
Send a message via MSN to liverchip
Remove the tank first. 8)
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
