DIY fender eliminator
2019 Apollo 250rx not even 100 miles on it and I have to start tinkering. I decided after looking closely at the rear fender of my Apollo, I could make my own fender eliminator out of pretty much everything on the bike. I started by chopping everything under the tail light. I would relocate the license plate mount and light. I tried to "tuck" the taillight up to the rear fender by making the holes oval. Turn signals mount in the exact same place as well. I drilled a hole for the license plate bracket and used an existing bolt to mount that. $0 dollars spent and a little time and handy work with a cut off wheel, I think it cleaned the back of the bike up nicely. I used a Dremel to smooth out all my cuts and oblong the holes for the taillight as well.
Great idea thanks for sharing.
