02-19-2024, 02:09 PM | #121 |
What would cause that to happen. All the other spokes are fine, the wheel is true. BTW are you the Bruce from endlessjourneyscycles or something it was called 15 years ago up in Ohio?
2022 Hawk 250 |
02-19-2024, 02:58 PM | #122 |
oh by the way I had to replace my kill switch. easy to do. but I think its backwards. the button on top is on and the middle button is off. I could have swore it was different.
2022 Hawk 250 |
02-19-2024, 04:20 PM | #123 |
The wheel is under tension ,the stresses are huge and are designed to be equal all around the wheel ,your missing a spoke on a cheaply made wheel ,so now the other spokes are having to do the work of their missing brother and eventually they will start failing and literally the wheel will collapse .Let me ask you a question ,do you understand that your entire bike is made with the cheapest parts they can find ,in order to sell it as cheap as they do ? Then ,why did they bother to put so many spokes on your wheels if they are not needed ?
02-19-2024, 08:13 PM | #124 |
I know that a rim is one of the expensive items, but your rim can probably be saved. All it needs is to be able to hold the " head" in the rim without pulling through, and be countersunk about as flush as the others. I would try either a small conical washer, or if you could find one of those real thin washers and use a small bolt and tap to pull it down in the recess. A star lock washer would probably work, because they are thin. A second, and better option is to find a small body shop, or muffler shop,cand and have them tig weld the hole, and then just redrill it. If you know someone who welds, or could braize it then that's great, but even if you have to pay a little at a shop, it should not be too much. Unless your sure of a friends welding skills, then I don't think I would let them try a wire feed or arc weld, because they may burn the hole even bigger. Anyway it's worth trying to fix.
02-20-2024, 06:06 PM | #125 | |
I am so sick of the voice of reason messing with my plans.
2022 Hawk 250 |
02-20-2024, 06:07 PM | #126 | |
2022 Hawk 250 |
02-21-2024, 09:27 PM | #127 |
Peace of mind......priceless.
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
02-23-2024, 05:46 PM | #128 |
Well, I once again risked my life on the Hawk today. The weather was pretty decent, so I took it up to Wheeling, then out the creek, and finally, home. Put about 70 miles on it. It just keeps chugging along, but I just wish my body was made of rubber or something! Anyway, had to share. Not sure why, but I had to.
I can't wait for spring. Every dang time I think I wanna get rid of the bike, the weather breaks, and I take her for a ride and remember what she means to me. She's my independence. I'll never be able to sell her and get anywhere near what I've put into her or what she means to me. I think I'm right around 2 grand at this point. It's money well spent. Even as I'm lying in my hospice bed years from now, with my bones ground into dust from not getting a counterbalanced motor, I'll look back fondly on these days and remember all of you.
2022 Hawk 250 |
02-23-2024, 06:17 PM | #129 | |
02-23-2024, 08:13 PM | #130 |
The problem is when the engine vibration is out of sync with the vibrations in my soul. When that happens, I have to take a deep breath and then remind myself I am completely insane and not to take my thoughts too seriously.
2022 Hawk 250 |
02-23-2024, 08:39 PM | #131 |
Its a single cylinder, they don't call them thumpers for nothing...
Sure a balance shaft helps a bit but really its baked into the engine dynamics. I was getting numb thumbs for awhile but then I learned to relax my grip and overall riding posture which overtime the vibrations seem less taxing to the point I stopped noticing... However I think my phat tapered bars and pillow grips helped. I think most fatigue issues are just bad riding habits and poor ergonomic setups for the most part. Still advised to take rest stops. |
02-24-2024, 05:10 AM | #132 |
Yeah yesterday I took note of the fact that I am gripping very tightly and I need to relax that grip somewhat.
2022 Hawk 250 |
02-24-2024, 08:29 PM | #133 | |
My buddy's TT250 is counterbalanced. It's a little smoother, but I've always been in positions where I had to adapt to what I could get my hands on rather picking and choosing........"beggars can't be choosers" would be the phrase that applies to me, not that I beg. I pride myself in being adaptable.
02-24-2024, 08:34 PM | #134 |
I'm not a fan of the stock seemingly hard plastic waffle grips on my Hawk DLX, but vibration isn't an issue and the image in my mirrors is just fine. If I stare at a stop, I can see my front fender vibrating, otherwise, I don't really notice.
02-26-2024, 07:55 PM | #135 |
I had a 2007 Lifan GY-5 that was counterbalanced. Looking back on it now, it was half the bike my Hawk is. But somewhat smoother. It did have better quality controls and electronics and shit and that was back in 2008 when I had it. It was just less robust..that is the only way I can explain it and also..it was pretty much worn out when I sold it at 10000 units (6000 miles) and in comparison, my Hawk is just getting started. But..I dont beat on it like a dirtbike I use it as a commuter. That is a big factor here. I wish someone would trade me for a street bike. its killing me guys., roids and my bones.
2022 Hawk 250 |
