Old 09-12-2015, 02:01 AM   #106
Co2   Co2 is offline
Another carburated version of ZS177MM my moto Xmotos XZ250RM , fabricated mounted coming with DELLORTO PHBE 34 mm , i buy this moto on 2013 , but moto model is product 2011 , and probably sleep in fabrica , and first day surprised my exhaust color chanced Gold yellow :(
After day i research and found problem is carburator in old benzin carb bowl benzin returned paste ( 2 year stay in old test benzin), blocked carb jets bad surprise.
But Dellorto phbe 34mm carb , non vacum type, spray type i think generally used hot italian 2 stroke bikes , basic constuction, basic maintenance and clean, i like.
I'm try KOSO / OSO 32mm carb , but poor performance (probably need , big jet's, low rpm good but high rpm poor probblem , and manifold gasket harmony problem)
Spark plug trying changing, moto coming DENSO U24 ESR-NB ( good performance) , (big head type"spark plug head attent") ,
Sparkplug crossreference found sad NGK CR8 , i try iridium version CR8EIX ( low rpm very good, but high.. Denso better than NGK)
Owner manual writed sparkplug adviced Champion RG6YC , i try found that sparkplug but cant found , idk how performance or stable..
İgnition coil , i found a old waste Skyteam 200cc cross bike , old ignition coil (same build type) , and i tested Skyteam 200cc ignition coil better than orginal coil , but old and dirty, i try found zero new cant found.
I was wondering , which other carburator types on harmony ZS177mm ?
( forgive me please, grammer and poor english, my age 36 and populer Turk terminology said " age is 35 Half of the way " ,^^ im happy in this forum platform )
Old 09-12-2015, 06:42 PM   #107
Jay In Milpitas's Avatar
Co2, Your English is much better than my Turkish (none).
So after you cleaned the old benzin (gasoline) out, the carb is good for performance?
Jay
Old 09-12-2015, 07:50 PM   #108
humanbeing's Avatar
...was wondering , which other carburator types on harmony ZS177mm ?...
ZS fitted this http://item.taobao.com/item.htm?id=22059759145 Mikuni
Teikei http://item.taobao.com/item.htm?id=15775593313 | http://detail.tmall.com/item.htm?id=45067073447 is quite popular among chinese 250 (Gn250/Ax-1/Nc250...) rider
"Racers" had their own favorites https://item.taobao.com/item.htm?id=40650969335
Old 09-13-2015, 02:25 AM   #109
Co2   Co2 is offline
Jay
Jay , thanks for increase morale, good mesage
Yes after clean carb , show must go on ^^ my moto monster power , but terrible situation before clean, clean methode ultrasonic cleaner (little size) , with printer cartrige cleaner solution very good cleaned all parts and shined
A bit problem is air screw setting , i solved it, smell work moto exhaust gasoline, yep my nose same co2 and carbonmonoxide sensor
Exhaust sıound ( i cant like high volume sounds, but moto original exhaust uniqe bass, of course mobile phone cam, and volume bad on video.)
First 65 kilometer vide :( , now 16.000 , and replacment parts (my multiple faults)
That account :/ i forget it which pass , video is after clean carb, a bit rölanti fluctuation
My old topic ( some photos deleting automaticly, free picture server...)
http://www.motosiklet.net/forum/moto...m-basligi.html
Old 09-13-2015, 02:37 AM   #110
Co2   Co2 is offline
Humanbeing i looking types vacum, i cold looked vacum types, last link is spray type , but same i have my test version thank you very much
Fresh photos
Old 10-06-2015, 11:12 AM   #111
peperino   peperino is offline
Here's a step by step procedure I made to adjust the tank float height, specially useful for us carbureted version users.
It's in spanish but you probably can google translate it
https://coltermoto.wordpress.com/tri...ible-flotante/
Old 10-06-2015, 03:44 PM   #112
Thanks for posting the link to your tank float modification. Google Chrome translates the page well into English.
Old 10-06-2015, 03:50 PM   #113
I still have to test and fine tune, was raining today so I couldn't test it
Old 10-06-2015, 04:11 PM   #114
We eagerly await your updates.
Would you consider starting a new thread on this topic here? I'm sure the thread would be very popular with all Zongshen RX3 owners, everywhere.
Old 10-06-2015, 04:12 PM   #115
Sure thing
Old 10-06-2015, 04:16 PM   #116
Thank you, amigo.
Old 10-12-2015, 10:05 AM   #117
jezzrite   jezzrite is offline
Send a message via Skype™ to jezzrite
Carburetor problem
Hello guys. Long time no see.
This evening I run out of fuel while heading to a petrol station, which is luckily just a hundred metres away from where my bike died (the petcock was already at RESERVE).
After I finished topping up fuel, I was unable to start the bike, and fuel was seen coming out from the area in red circle.
I had to switch the petcock to OFF position to prevent the leak from draining my tank. It leaks when I put it at ON or RESERVE.
And the Zong still won't start after a good 15 minutes of cranking up the engine via starter.
What did I do wrong?
People sit on an exploding, volatile, fast-moving two-wheeled killer machine, and call it "enjoying the moment".
No wonder aliens never make contact with us.
-A Zong rider-
Old 10-12-2015, 02:54 PM   #118
It sounds like the float is stuck. Try tapping the bowl with a screwdriver handle.
Old 10-12-2015, 02:55 PM   #119
Old 10-14-2015, 01:54 AM   #120
Too occupied with work, and suffered Post Ride Syndrome after a trip to India.
Only able to try it last night.
And it worked! Thanks Weldangrind
But before coming to life, the exhaust make a loud explosion-like sound. Not "pop" kind of sound, but more like a "boom".
After that, no more leaks, and the engine starts like normal.
I'm guessing it's a temporary fix, isn't it?
How do I make a permanent fix? Change the float needle? My bike still under warranty, and I called the dealer, and they said I can change the carb if I like to.
Any words of wisdom?
-A Zong rider-
