Old 04-25-2019, 02:26 AM   #1
New Hawk, new adventures.
Updated as of 5/8/24.
Modifications:
Engine.
1. Motocult ported head with undercut valves.
2. Motocult 70mm Big bore cylinder kit.
3. NGK DPR8EIX-9 Spark Plug.
4. Shortened factory plug wire with NGK XDO5F plug cap with resistor removed.
5. 125ml sump drawn Oil Cooler. https://www.aliexpress.com/i/32913143396.html
6. Mikuni VM26 30mm carb. 120 Main jet, 25 pilot jet, needle middle notch.
7. Dual layer foam pod filter.
8. Nibbi Performance ignition coil.
9. Kajimotor CRF exhaust system - modified mid pipe mount.
10. WGK 1010851 "Bravo" 292 Cam
11. Roller Cam followers.
12. Performance CRF230F PROCOM CDI.
Chassis/Suspension/Brakes
1. YSS PD238 Fork valves with custom made adapters. 15wt oil.
2. Bashan Brozz rear swing arm.
3. Fast Ace Bs-22ar/bda01ar 280mm rear shock with 1000lb/in spring
4. CG125 Cafe front fender.
5. Sintered brake pads front and rear.
6. Upgraded Master Cylinder and clutch base with factory levers.
7. Goodrich banjo bolt brake switch for rear brake.
Chain, Sprockets, and shifter
1. DID VX2 520 Chain, 98 Links
2. Front Sprocket - JTF328 13 tooth
3. Rear Sprocket - JTR279 33 tooth
4. Honda Sprocket Studs - 90128-KE2-940
5. IMS Flightline Folding Shift Lever - model 312223 for XR400.
Tires
Shinko 700. Front 3.0x21 and Rear 4.6x18 with heavy duty IRC tubes.
Controls/Display
1. Digital Tach cluster sold by Matt (no longer available).
2. Renthal Fat Bars
3. Adjustable riser adapters.
4. Quarter turn throttle assembly.
5. Progrip 737BK Grips.
6. Round swing-away style mirrors.
Lighting/Electrical.
1. 7 Inch Round Headlight conversion with CNC brackets and LED headlight.
2. 1157 LED Tail/Brake bulb from Superbright LEDs.
3. Motogadget M-Blaze Pin turn signals. (from an old project)
4. Upgraded main ground strap to 8awg wire.
5. YTZ7S Battery.
6. Upgraded main fuse to blade style with waterproof holder.
7 Most original connectors have been upgraded to weatherpack style.
Miscellanious
1. CSC TT250 rear luggage rack.
2. TT250 Seat
Top Speed: 79mph. Repeatable/Consistent top speed: 75mph.
A few pictures as it currently sits.
