Old 03-11-2010, 01:03 AM   #61
Thanks Spud. I guess I could have checked; we have Google where I live.
Old 03-11-2010, 01:20 AM   #62
No problema, amigo.
Old 03-11-2010, 11:28 AM   #63
I took it to work today. It runs well, although it's no Gold Wing! Bikes have changed a lot in the past 33 years. So have I. :?
Old 03-11-2010, 12:22 PM   #64
Amen. I am glad the bike runs well.
Old 03-11-2010, 01:20 PM   #65
Maybe I'll give this a try. Cheap. Very much in keeping with the Chinarider's tradition!
http://www.powerchutes.com/manometer.asp
Old 03-11-2010, 01:29 PM   #66
Indeed, how can you go wrong for $1.55?
Old 03-11-2010, 10:21 PM   #67
Reveeen   Reveeen is offline
There is/was a tool called a uni-sync that you used on multiple carb set-ups on cars that works just fine on twins.
http://www.1800vw.bizhosting.com/uni_sync.html
What I do is remove the air cleaners and use a piece of vacuum hose, one end in your ear (to listen) the other end down the throat of the carb, both carbs should sound the same, adjust the idle speed screws until they do. (this is provided there is one cable pulling both carbs open, you set the one that is fixed to the shaft then adjust the other that has the adjustment independent of the shaft. A two cable set-up is set differently and is really time consuming as you have to set the idle speeds (with the idle speed screws) then set the cables (adjust the lengths) at around 1500rpm)
Old 03-12-2010, 12:22 AM   #68
It occurs to me I'd also need some sort of adapter to put the hose onto the fitting of the carb. I think I'll just let Andy do it. He's do it for free in exchange for a flying lesson. I've got it good, gentlemen. Except for that divorce thing, but even that has it's up sides. :?
Old 03-12-2010, 08:03 AM   #69
katoranger's Avatar
Even more fun. 4 carbs. A friend likes the early wings.
Old 03-12-2010, 11:12 AM   #70
I has a GS1100 for about 15 years and did the carbs on it. time consuming but not rocket science. Problem is I've long ago lost/broken the mercury manometer. :(
Old 03-12-2010, 04:09 PM   #71
Another pic for Spud, et al.
Hopefully it's cool 'Collector Vehicle" plate shows up in the picture.
Old 03-12-2010, 04:56 PM   #72
Thanks, Doc. Every time I look at your bike, I wish I still owned my 1979, Honda Hawk II.
Old 03-12-2010, 05:10 PM   #73
When you're in my neighborhood, you are welcome to ride the 400, my 1978 GS750, Q, the Kawasaki Bayou, and if you feel up to it, the 850 pound 125HP Gold Wing 8O
Old 03-12-2010, 05:22 PM   #74
Thank you, Doc! The next time I pass your way, I will gladly accept your kind offer.
