Old 12-02-2018, 04:25 PM   #61
Barnone   Barnone is offline
Barnone's Avatar
Zongshen 250cc 165FMM Air Cooled Motorcycle Engine
Performance Parameter
Engine Mode ZS165FMM
Engine Name CB250D-G
Engine Type Single cylinder,4-stroke, air-cooling,camshaft upward
Displacement(ml) 223
Dimension(mm×mm×mm) 375×297×405
Net Weight(kg) 31
Max.Power(kw/r/min) 12/7000
Max.Torque(N.m/r/min) 17.5/5500
Compression Ratio 9.3-9.9:1
Bore and Stroke(mm×mm) 65.5×62.2
Ignition method CDI
Lubrication method Pressure and Splash
Min.Fuel Consumption(a/Kw.h) ≤354
Starting method Electric/kick
Clutch method Manual Wet Multi-Plate
Gearshift Method Constant mesh,two stage transmission, 5-speed Gearshift
Old 12-02-2018, 04:42 PM   #62
Barnone's Avatar
Carb Dekni PZ30
Tuning manual PZ30 is like PZ26
http://www.ccwthariders.com/uploads/...ing_manual.pdf
Old 12-02-2018, 05:15 PM   #63
Azhule   Azhule is offline
Originally Posted by Barnone View Post
What China bike were you riding at 80+ MPH?
I like to ride the Mrs. Bashan "WILL" 200 at those speeds to get myself to the mountain trails a wee bit faster I have held 75 to 80+ mph for several hours (2 to 4) at a time and the bike is still running strong after 4k miles
197cc Lifan engine is powering that little bike... 17t and 39t sprockets to help get that highway speed... little issues "off road/mountain trailing" with that gearing choice and my massive 108lbs on the bike (lost some more weight recently )
Old 12-02-2018, 05:44 PM   #64
Riggs   Riggs is offline
Riggs's Avatar
Top speed towing aosom trailer?
Hooked up one of my Aosom bicycle trailers to the DF and took her for a test run. All is well. I use these trailers in the mountains when I have to make a garbage, recycling, grocery, etc run.
Hey Barnone. How fast can you go towing that bicycle trailer?
And if trailer is modified please elaborate. Thanks.
Old 12-02-2018, 06:04 PM   #65
Barnone's Avatar
Never over 65 MPH towing the trailer behind my long gone W650. Only mod is changing out the tires and wheels from the bicycle ones after they wore out. Now I am running pit bike wheels on both the trailers. Have one of the trailers in Fort Myers Fl for the winter. The other is in WNC close to Robbinsville, NC. Use the one in the mountains a lot. Not so much in FL.
Old 12-02-2018, 11:54 PM   #66
Have you checked the accuracy of your speedometer?
I have, it has a digital Trail Tech Vapor with an extremely accurate speedo after I measured the wheel and did the initial maths, took a ride, it was a little off and I played around with the numbers for a few rides until it was dead on accurate with a 5 mile trip from pops garage to a local gas station.
Now with 83 mph showing on both a follow vehicle and 2 GPS devices (one phone, one garmin) and the bike was showing 82.6 (and slowly climbing) mph on the speedo
No way I would still be around going slow on I-25... round these parts speed limit is 65 to 75 mph from my house to the mountains... traffic rarely goes slower than 80 though...
Old 12-03-2018, 12:30 AM   #67
MDStroup   MDStroup is offline
MDStroup's Avatar
Wow! That engine has some get up and go!! What model exactly do you have?
Old 12-03-2018, 12:32 AM   #68
MDStroup's Avatar
Carb Dekni PZ30
No choke but it starts up just fine if you give it a little throttle.
Thanks. So it doesn't look like you can upgrade the carb to a larger one as it already has a larger one on it.
Old 12-03-2018, 12:23 PM   #69
Goes by many "model names"
Bashan "WILL" 200 ; BS200GY-9 ; Roketa DB-03-200 ; was last made back in 2014
Well, I think that is enough of my nonsense in Barnone's thread this is about a DF250RTG after all
Old 12-04-2018, 01:03 PM   #70
Barnone's Avatar
Put some saddlebags on her.
Old 12-04-2018, 05:42 PM   #71
Azhule has the World's Faster Bashan WILL! Of course, it helps that he tips the scales at about 85 pounds, soaking wet... ;-)
Old 12-04-2018, 06:08 PM   #72
It's amazing how fast a toothpick can go sitting on top of an engine with wheels , I'm free for any land speed records if anyone wants the same title on their bike ("Worlds Fastest China Bike" badge/sticker sales soon to follow)
Nice saddlebags, is the exhaust heat going to be friendly with them being that close?
Old 12-07-2018, 12:47 PM   #73
Barnone's Avatar
More photos. Off to the beach to find a bikini model.
Old 12-07-2018, 01:49 PM   #74
Bags and foot rest look nice.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 12-07-2018, 03:08 PM   #75
MDStroup's Avatar
Loving how this is turning out so far. Will definitely keep my on this as my other motorcycle deal fell thru.
Keep us updated if any mechanical problems arise! Hoping none do for you though.
I only hope one day they will start selling a china bike that is highway capable.
